raw fuel
my sy.#2280
what do i need to look at when i start it up i smell raw fuel then it goes away it runs good
and it repones like it should i'm thinking that maybe somthing is going to go wrong with it.
Bill Z
Re: raw fuel
fabricator said:
my sy.#2280
Raw Fuel could mean anything from a leak in the fuel line to sticking injectors. What ever, it WILL lead to more cost somewhere down the line.
If problem is inside the engine (sticking injector) it can cause a clogging of the cat which increases back pressure. Also, you probably won't pass emission test (if required).
If problem is a leak outside the engine, you are risking fire hazard.
Ether way, at $3.00 a gallon, it is costing you more money than you need to spend.
