Razor Alky Injection
I have a used Razor Alky injection kit in good condition, It is the first gen kit. It was working intermittently when I pulled my motor out. I bought a new kit when I installed my new motor. When I uninstalled the interior wiring I found the terminal block power screws loose. I am confident this was the problem, I will guarentee this kit will work.
I have some new parts from the new razor kit (overflow hoses, pump mount, green map wiring, punp hose) that i either reused what i had or didnt use. I also upgrade the power wiring to the new style kit with relay power source from the distribution block on the firewall.
I have instructions as well. $300 plus shipping.
Re: Razor Alky Injection
I updated the post, I sourced the missing front control box plate I was missing and added the missing resistor/power on LED. This kit has super low usage even though it is older. I didn't even go through on tank of methanol (it actually evaporated on me). I basically installed the kit and it was working, the truck was running rich with the alky on a ultimate chip. I decided to get serious about tuning, I turned off the alky kit and started working on my tune and knock retard I was getting. During this tuning process I determine something was definitely wrong with my truck. The next year I turned the alky kit on and realized it wasn't working (loose terminal block screw that connected to the alky pump) and then pulled my motor apart to find a cracked piston ring land etc. My last sale fell apart, so the alky kit is still available.
bryan
I sold my used kit for $75. Can you say "big mistake"? Now I'm buying another for triple that. Go figure...
