Re-doing my front suspension
2500avalanche
Well-known member
SO, after 100k, I figured I since the top of my truck is looking good, the underneath needed attention. First, the transfercase was junk, so a new one. then I looked under with the layers of grease and oil. I spent 2 months taking off the grease from the bottom of the truck. the truck is a southern vehicle so no rust, and I actually waxed the underside. I painted the frame rails, and recently got the the front end.
With the help of Dave P talking me tthrough, I took off my control arms (have new ones painted, ready to go on). The torsion bars were easy to get off. In fact, I tapped the control arm with a rubber mallet, and it slid off of the torsion bar!
The amount of grease under the truck was disgusting. Now it is nice and clean.
I have to drop the gas tank, and paint the leaf springs, but that will be it!
I will be updating this thread over the next week or so as I get everything back in the truck.
Here is the front end (have the intercooler and bumper off
Here it is after I removed the arms and everything. This will be painted and cleaned tomorrow!
The bilsten shock cleaned as well as a new control arm
One of the torsion bars.
I cleaned it, and this is the factory color, green. I am not sure if I will keep it this green or paint it gray
Painted the new tierod ends
Re: Re-doing my front suspension
Interesting project. :2cents: Be sure to inspect the four upper a-arm attachment bolts. That they and/or the offset alignment washers aren't worn.
Ty92Resto
Thanks for the posts on the front suspension. Going to be doing this in the next few months and was a bit concerned about how to handle the tension in the front and not get hurt. Arms, coils, tie rods, shocks, and all bolts to start will be replaced.
Would you say the torsion bar key is necessary? Have read both ways but looking like it would be best to use but a bit pricey. Perhaps can rent one/pay shipping from someone.
2500avalanche
Well-known member
I was worried about that too. The torsion tool is 41$ on amazon. I just purchased it because I was scared of something shooting out at me.
I actually did the drivers side without it (it hasnt come yet). I will do the passenger side using it.
Was not to difficult not using it, but I heard you need it when putting everything back together.
Just take your time and be smart. I triple checked everything, and if I did not feel comfortable, I stopped.
liquidswords88
I pity da fool
I bought mine on eBay for 32 bucks free shipping. The job can be done with a normal c clamp as well. The tension on the syty trucks is the lowest tension bar you are going to find anywhere. Some heavy duty trucks have torsion bars that could kill you it conditions were at their worst. Make sure that when you reinstall the bars you look at the ends. They will have a L and R. L being driver side and R being pass. There will also be a half circle arrow, the arrow points towards the tension. If the bars are brand new it does not matter, but after the tension being on them for years the take a set and must be reinstalled the same as they were removed.
2500avalanche
Well-known member
Thanks!
I marked everything so I have my items all aligned.
Ty92Resto
$32 and $40 isn't bad. Had a quick look and showed a few over $100. Will check out ebay. Good to also know they need to be installed back where they came from, had no idea. Thanks!
SEL777
One of 101
If you have the coin, just do the coil overs Sport Machine sells.Why spend all the time and rebuild all of the front suspension and put the old torque bar stuff back on.You can do on the cheap and just get the shock, they work with the factory a-arms. I pulled that crap out and never looked back.
Aeroking
e.i.
I pulled my bars out without any tool. I didn't know it was necessary, lol.
Looking good. Can't wait for Carlisle
2500avalanche
Well-known member
Would love to, but trying to keep close to stock. Don't have the funds to do that. Next on teh list is F body brakes. Have the brackets, but need the calipers and the rotors...
