re "Injector flow Rate" Noob questions
vortecfiero
at location
0x0328 KDISFS Injector Flow Rate 4.9 gal/hr
is this and the F28 table (set porportionatly ? (.5696 for 50 lbers) ) the starting point to a 50lb set up, besides 3 bar mods and fine tuning ?
also does any body have a link(s) to a fairly detailed how to site
I have the P 4 doccument...
thanks
leroy
The injector flow rate is for mpg calculation purposes. It is not a factor in the base pulse width.
Jim
jwaller
Evil Genius/SyTy Guru
0x040E F28_TABLE Base Pulse Const. vs Desired EGR
This is the closest thing we have to an injector constant in our chip. This value is a direct fuel multiplier. Multiply the values in this table by 1.5, your injector pulsewidths will be 1.5 times longer across the board. When working with larger
injectors, this should be the first table you rescale.
vortecfiero
Thanks, I have article too
in the F28 table
Do you scale proportately 32lbs = .89, so 50lbs = 1.39
or inversely proportionate 50lbs = .5696 ?
