read datamaster
johnboy89
Re: read datamaster
I took a quick look at it I'm no expert, but here is what I noticed:
  • IA Temps are high, but that might be because you have a stock chip either way might want to hot wire the pump to get those temps down???
  • Engine temp. also seems a bit high, what do you have for a thermostat in it?? I run a 180 in mine.
  • You're seeing knock all over the place with no changes in TPS???? False knock maybe, anything banging, sensor and wire tight???
Is you truck stock???
John
randy merritt
Re: read datamaster
John
false knock is what I was thinking. the short term knock counts are not bad, but the tune pulls a lot of timing out. A wide open throttle run would be nice if possible. the truck is running in closed loop, so a pull at WOT would show the open loop timing, and narrow band o2. not an expert, just my thoughts.
sychris
Re: read datamaster
im going to change the thermostat today . and i was almost wide open but the TPS ONLY SHOWS 83% . ill do a wide open run and post it . IA temps could be up cause the air filter is on the turbo side . i have to relocate battery or build a heat shield for the filter
sychris
Re: read datamaster
http://www.mediafire.com/?zl8ft262ks4l98k
http://www.mediafire.com/?cq8qseqfr01c35f
i seem to be getting alot of retard when im just spooling up turbo but when im wide open it goes away ? wtf . stock chip full exhaust .
Flyin Ryan
hated cuz he drives fords
Re: read datamaster
Put the truck in N and rev it up and see if any KR shows.. bet it's false knock
sychris
Re: read datamaster
where else can i look for false knock . where is the knock sensor ? but im not hitting bumps in road or anything it does it on smooth runs . it seems like it only retards when im at like 25 tps and right when the turbo starts to spool up .
sychris
Re: read datamaster
is it damaging to the engine when it retards like that at low speeds just cruising around at 25 tps . cause when i get on it the retard goes away
sychris
Re: read datamaster
where is the knock sensor . im tryin to make sure nothing is hitting anything for a false knock .
Flyin Ryan
Re: read datamaster
Knock sensor is round and behind the dizzy in a real shitty area..... Make sure urnfuel and trains lines aren't banging each other or the frame.
sychris
Re: read datamaster
what are good IC temps for our trucks. is mine high? my intercooler always feels cool when the pump is workin , but i dont like how its run , alot of hose some couplings and sharp turns . it also runs through the a/c condensor where both outlets are on bottom and i dont like that . a/c delete
sychris
Re: read datamaster
truck is mostly stock . have a short intake with cone filter . adjustable fuel reg , BOV , everything is tight . no a/c . good plugs i noticed there are 7mm ac delco wires ? ,brass cap . full exhaust . stock chip i think but i saw a reading over 15psi boost ?
randy merritt
Re: read datamaster
IAT's look good. Very conservitive timing (stock, I guess). I would bet money of a false knock. Does not look like you are running lean. Maybe your knock sensor is bad or is not torqued to correct specs? Check for anything that could be hitting the block/trans. Check for broken motor/trans mounts.
HTH
Randy
