Reading the truck's SES codes Q.
sytyfreak
ok, I'm reading the truck's codes manually(paper clip). I can get to read the 3 consecutive 12 code. then the truck keeps spilling codes. My question is if the truck detected the same malfunction let's say code 34 four different times, at the time of reading the codes, will the truck show code 34 four times or one time??? cause I'm getting a SHIT LOAD of codes and all I can read is like 3 different codes, but 3 times each :eek:
Thanx
sytyguy
Moderated User
Will only set each code once. Best thing to do if you have a lot of codes, is get someone to write them down as you call them out, so as to not take your eye off the CE light. You get sequences of three .... 12,12,12 ... 24,24,24 ... 36,36,36 ... etc..... and three more 12s at the end to signify the end of the code sequence.
If you have a code, check below for more info on it and search the archives for the best way to go about resolving whatever the issue may be (i.e. - actually fixing the problem, sticking a piece of electrical tape over the CE light, etc....). FWIW, grab a scantool.....makes it much easier to check codes.....and preserve the life of your truck.
http://www.georgiasyty.com/aldl.htm
HTHs
Michael
sytyfreak
Michael,
Thanx for your response! You answered my Q very precisely. About the scantool, well I've been trying to buy one ever since I thought of modding the truck, but each time I have saved enough money the truck breaks something and the money is lost reparing the truck. Don't worry, for Chrismas I'll get a scantool.
thanx
sytyguy
Moderated User
IMHO, Datamaster is tops, but the Actron Scantool that most retail parts stores sell (namely AutoZone & Advance), is a pretty good alternative. Nowhere near the capabilities of Datamaster, but not as bundlesome or expensive as a laptop setup and does power up instantly. Plus, it's easy to keep behind the seat and has no battery life (cigarette lighter powered).
Whatever codes you do find, I hope they're easy to resolve. I remember when mine was always breaking (crossing fingers), it was a frustrating time.
Good luck,
Michael
V6 Kompressor
After recording all the codes, disconnect the battery for at least 30 seconds (this clears all of those codes), then test drive the truck and see if the light comes back on. The reason for doing this is some of the codes are probably old and never got cleared, so you may be chasing phantom problems and spending time and money on something that is not needed. If there is something wrong, the valid codes will come back... then troubleshoot those codes... use the search button at the upper right hand corner of this page and see what others have found/answers they have recieved to the very same codes. Good luck!
sytyfreak
Good luck,
Michael
Thanx for the info and for all the help Michael. As for the scantool, I have thought of buying one of hose code scaners. But, since I wanted datamaster from the beginning and I already got a laptop I'll get datamaster first.
I'm doing my best to go thru that situation as best as I can. I just hope to have a good and healthy running truck for 03.
thanx!
sytyfreak
v6compressor,
Thanx for the advice, I will do it right now. I didn't think about that before :oops:
Thanx and take care!
InvisiBill
Good luck,
Michael
Do these Actron scanners do anything other than pull codes? The ones I've seen don't seem to do anything else, so I've decided that not having to count flashes just isn't worth even $25 to me. My paperclip and brain are free, and work just as well. Check out http://www.techweasel.com/articles/troublecode/GM.htm for lots of info too.
sytyguy
Moderated User
I'm not referring to just the code readers....there is an Actron Scantool (CP9110) which does read and identify codes as well as give real-time data viewing. Like I said, although not as powerful as Datamaster, it still has the essentials (Int, BLM, O2, knock, MAT, Spark Adv, TPS, Boost, etc........). Also allows you to put the vehicle in field service mode, go ALDL mode racing :wink: , and it even has a record feature - although I have found this to be absolutely useless.
If I just wanna check one little thing (like MAT temps) I use this scanner. Much easier to pull it out from behind the seat than to set up an entire run on the laptop. Plus you can set up a custom view with whatever values you desire (i.e - MAT, O2, knock, Boost), allowing you to view the major things without having to scroll back and forth between values. If anyone has ever used the Matco unit (which I use on occasion, but the buttons are annoying), it's very similar.
http://www.actron.com/cgi-bin/web_store.cgi?page=cp9110.htm&cart_id=3713989_22127
It does cost $225 for the unit & the GM cartridge and sometimes has trouble linking with SyTys (due to the speed of the ECM), but it is a very convienent tool to have and scans any GM OBDI system (for the most part).
Michael
InvisiBill
Thanks for the info. I can see where having something like that would be handy for daily driving, as opposed to hauling a laptop/DM setup everyone (like the Scanmaster's appeal). However, if it's strictly for SyTy monitoring, you could probably get DM, a cable, and an old laptop for about the same cost or a little more, and it seems like it would be easier to diagnose your truck that way. Each has pros and cons...
