Real Time Bubble in TunerPro RT Coming
skwayb
NWSTP
Just to make sure this didn't get lost in Jeffs request for a ADL file post he made I am reposting this.
I asked Mark if I could let the cat out of the bag on the next version of TunerPro that Jeff and I have been playing with. He said go for it. This version (v 4.01) should be out in a couple of weeks. It doesn't fix our connection issue yet with our ecm but that will becoming in the next version after this. Any way on with the show... The next version of Tuner Pro RT will show you exactly where you are at in any table as long as you link the correct ALDL item(s) to the table. Here are a couple of shots of it in action.
These images have the Base VE -vs- RPM & MAP, Base Boost Multiplier (in kPa and in PSI) and the Spark Advance vs Rpm Vs Map tables linked to the correct ALDL items. The yellow highlighted cells are where it is currently at in each table. Mark did an awesome job. Can't wait until this is released. This should make tuning your stock ECM a lot easier.
mattw
Re: Real Time Bubble in TunerPro RT Coming
That is very nice... Does it do it on the graphs as well?
Thanks,
-Matt
Cool :tup:, I haven't done that much with mine, but I started seeing where that was going to be clunky to do. I made a converison chart to help me, but that will be in the trash if this works properly.
I have been playing with this new version for a week now, working on the definition files.
I can honestly saw even with the yet unrealsed beta version I have it works correctly. Mark has a few more things he is doing before release.
What Paul didn't show was the constants (for example redline) now can show an ALDL item (in this case I have it tied to rpm).
The 3d graphing code I heard was totally redone, and now offers more than just wireframe but a more colorful visual screen. You can multiselect several point on the graph and move up/down at will. (I prefer NOT to tune with graph myself).
The realtime does not move on graph. To me that isn't an issue, as a nice graph doesn't always mean a good tune.
skwayb
NWSTP
Here are some more pictures of the changes. Like Jeff said, ALDL Link to Constants and much Improved 3D and 2D graphs.
Here are the list of changes to the graphing in Tuner Pro v4.01
- completely re-wrote the 2D graphing control to include:
a) multli-selection
b) auto-range
c) auto-label
d) no more "distortion" when resizing the window
e) more performant code
f) much more
- completely re-wrote the 3D graphing control to include:
a) multi-selection
b) surface shading
c) auto-range
d) auto-label
f) no more distortion
g) much more
Constant link to ALDL value
New 3D Graph
New 3D Graph multi-point select
New 3D Graph multi-point Changes
Changes Made to the table (Items Changed turn RED)
Another new feature coming I just caught glimpse of is filter.
I am working on adding informotion to the def. files to let this work but it will allow you to select just the tables/info related to fuel for example.
Or you could drill down 1 more level and do fuel at idle. (depending how I setup the def. file.)
This could be very handy for people just getting started. The bubble tells you where it is at, the filter shows you what tables apply.
SY#2910
Banned
NICE ! ! ! I can't wait. Maybe now I can actually do some tuning myself :oops:
I already have a filter setup for you Will.
Kentucky Hill Billy.
You will be all good to go. :D :D
mattw
Its a good thing that there are people like you and Mark.. Otherwise idiots like me would be clueless when trying to figure this crap out..
Thanks,
-Matt
SpoolingTurbo6
Thanks for all the hard work everyone is doing to make tuning easy.Thank's Jeff for your work on the Def. files. And Paul Schwab for the countless hours of effort and beta test to make such a great program...
Tyson
Paul and I found a bug the other day, which Mark was able to fix right away.
Last night I was setting up the filters. This is going to be good for new users. As I have level 10 setup to be just the basic stuff you need 95% of the time.
As you move to level 9, 8, 7 more tables show up.
Eventually i will have another filter setup so you can filter for just idle tables, cruise, acceleration, etc.
The bubble still makes things very nice.
SY#2910
Banned
COOOOOL ! ! ! I will catch up with you Friday. Have been real busy and have had no time to even wash the truck in the last 2 weeks. :lol: I can't wait to see the differnece in the filters you have set up...
Thanks HOOSIER
Ian Turgeon
Cascading Inspiration
So are the emulator and datalogger working simoltaniously now?
Yes. There is still a minor bug/inconvience when hooking up to aldl information. But is mostly minor and is being worked on and has a work around by sending the silence ECM command several times.
With an Ostrich or Romulator this is now the ultimate stock ECM setup IMO.
SpoolingTurbo6
So, if someone is reading through this and wants to get into there own tunning....
What are the things they need. Hopefully this will help out others trying to piece stuff together
IE:computer?
os system?
Romulator or Ostrich?
cable for aldl hook up, USB or Port style?
Tunerpro download location and other software....like deff files
Just some info that might be questions of people reading this topic
Would be nice to have as a sticky hint hint
My personal suggestion is hardware from Moates.net
Ostrich and USB aldl cable
Laptop running xp helps, although 98 probably works
We try to keep the files updated on nwstp, although there is a chance we can get the new stuff in with the new build install.
Obviously the bubble and filter are not available yet, still working out some bugs with the author Mark. Already fixed several.
Ian Turgeon
Fantastic, it took a while but I understand this is a side project for Mark. Cant wait to get some time to play with my autoprom
Tooky
Serious about performance
ABSOLUTELY INCREDIBLE!!!! Wowzers! That's just a fantastic, groundbreaking feature! Real time viewing of which cells are active in the tune..... I'm "this" close to breaking out into a round of "For He's A Jolly Good Fellow"... :rotf: :lol: :cool: :D
Seriously, excellent work, gentlemen! :tup:
