Realy hot oil
DanenGraham
Big in the rear
ok when you check your oil does your dipstick tube smoke a little? and is the dipstick very(very) hot?
The motor runs cool, 160 therm.
Loeryder
No smoke should come out the dipstick when the engine is running.
But your oil should be checked with the engine off warm on level ground.
I think... at least thats what I have been doing.
SY2932
Administrator
If you get a little smoke when you withdrawl your dipstick with your motor good and hot, that is normal. The reason is the dipstick tube is close to the downpipe which gets extremely hot. Sometimes when you pull the dipstick out, a small amount of oil will touch the super heated dipstick tube and vaporize. HTH's
Mike Campbell
