Rear Disc Brake Kit
AutoVation
I can't seem to find a straightforward answer on this one.
I tried to buy some LS1 rear brackets but everyone is sold out. $75 for brackets is pretty high also. The kit from Baer is way too expensive @ $1300 but it does look nice.
firstsy
Re: Rear Disc Brake Kit
I'm going to try a IROC Z rear disc set up tomorrow I will post how the install goes.
silverblaz
I have a 2003 s10 rear disc set up calipers brackets backing plates all the bolts all you need is rotors pads ebrake shoes / hardware I have pics o and I have ebrake cables which you can easily make work with little thinking
let me know make me an offer
fauXGT
Brick Pilot
Been slowly working on mine. I'm using 98-02 Camaro, T/A rear set up. Backing plates, calipers, parking cables from local junk yard. Lucked out, car only had 30k mi. on it. A little paint & they look good. I'm having trouble dropping the posi unit in it (put a new eaton, in working on it tonight. might need bro-in-law's help), but you trim the axle backing plate to fit the disc backing plate. Drill holes to bolt the plate to axle, then slide shafts back in. Some say 1/4 inch spacers are needed. Haven't gotten to that mockup stage yet, but have spacers. The parking cables aren't fun either. Made up brackets to slide into shackle w/ the drop spacers for the wheel side of cable attachment. figured both old & Ca-T/A cables are same inside diameter, cut old center cable out of the tube (lop off end connector, slide out), do the same on other. Slide Ca-T/A center cable into old cable housing. It should drop back in from the wheel to the body, w/ Ca-T/A end on it to connect to backing plate. Then somehow splice into existing parking setup under body( u-clamp, splice tube etc...). Basically, unless you want to drop $1000+ on a bolt on set up that may or may not have parking brakes, hunting for parts & fabricating is what happens. :2cents:
