I didnt know that there was a teflon rear main available... :-?
If there is Id hope it would be softer than the teflon Im used to seeing as IMO it would wear into the crank over time worse than the rubber seals do. IMO its MUCH easier/cheaper to replace a worn out rubber seal than a crank shaft that has been cut into by a seal made from harder stuff.
This one appears to be very soft, low tension.
In fact, there is no spring that encircles the seal lip.
That's why I'm asking, it seems wimpy when compared to the regular seal.
