rear speed sensors
supersports10
Re: rear speed sensors
Sy777 said:
I will now clear up some misconseptions about 98+ brakes both front and rear on a typhoon.
1) They will bolt up by using the 98 + steering knuckle and lower control arm that has a
better front stabilizer bar mount.
correct, and incorrect, you are right about them working with the 98+ lower controll arm, but it is not required, the stock upp/ lower controll arm works also.
Sy777 said:
The 98+ flex hose will not attach to the stock metal line the thread size is different as well as the flare size. The stock sy or ty rubber flex hose is too short to work with the 98+ calipers and metal brake line on the frame. so the solution would be to have custom metal lines made or get the mtal lines off a 98+ 4x4 blazer or s10.
incorrect... i used the 98+ hose with no problems, direct bolt in.
Syclone#2960
What ever it takes!!
These sensors are for the ABS only right? If I remove them my speedo will still work? Doing C-clip elimantors axles.
blk00z28
Forced to by choice
When you get to dong this, can you post up pictures. I know there have been a lot of people asking what all was involved in doing c-clip elmin's (me included) and that would be a great post. :tup:
Syclone#2960
Dude you have no idea what a f*wkin pain it is to do...I will take pics & post it up.:tup:
blk00z28
Forced to by choice
Sweet! Yeah everyone says to do it but no one has any pictures or a how to do it yourself. You'd be the man if you made that writeup or just a FYI thread with lots of pictures and info.
Jeremy
Morning, following along and just curious if any one knows about the rear disc conversion kit from SSBC? I wanted to know if you could still retain the ABS while using this kit? Thanks for your input.
Syclone#2960
No clue.:(
