Re: Rebuilding engine...
I have the same goal with my build. I guess the best way to attack it is to make a plan and do your best to keep to it. I wanted a Daily Driver 350Hp truck, so I picked a strong bottom end or the strongest I could buy. SRP, Eagles, Cryo Crank, 77 bearings, hoping that I didn't have to think about it for a little awhile. Then I just picked the parts that would get me to the HP goal the best way; Vortec heads, 412 cam (hope to pass smog) 875 Lifters, and 1.52 roller tips. Then the Turbo, you can go so many ways with the turbo. It is basically witch way do you want to go. I wanted to keep the stock down pipe and the stock Intercooler (for now) so I went with RPM bolt-on turbo, Stage two, and got my hands on a torque converter to match the turbo. 7 grand later and she is almost ready to start. Just my :2cents: I hope this helps you
