Espritmike
Another case of "while I'm in there" I am having the turbo rebuilt ( nothing wrong with it) just going through it while building motor. Was wondering if I should do anything to it when it's being built?
Mostly stock. Did a walbro 255 fuel pump. Going to hot-wire or chip intercooler pump to run all the time. Exhaust wrap crossover and down pipe NGK plugs , new ignition (MSD) parts, may run new intercooler hoses. All new silicone vac hoses. New pcvs' and hoses (expensive stock). Had injectors cleaned (stock)
Seems like you are not looking for much power increase?
If so,just get a 57 MM compressor wheel,have it balanced & get your compressor cover machined to fit the 57 MM compressor wheel.:tup:
Note: Be sure to have your turbine wheel clipped to @ least give you a little better breathing for more top end.
I am istalling an adustable regulator BTW what shoul I set it to?
Depends on when I where it starts to have knock.
My wastegate spring is 15 psi min boost.
I also use an AEM Tru electronic boost controller. Works great! :tup::tup:
Stock is around 6 psi IIRC.
Start @ 6 & work you way up & watch for knock.:tup:
Did you get your turbo back already?
I'm not sure, but I think he was talking about fuel pressure.
If that is the case I would start at 45 pounds with the vacuum hose plugged, then reconnect the vacuum hose. Used DM so you can see what your engine is doing.
I would install an adjustable fuel pressure regulator also.
Just looked up comp turbo on the net..
Comp Turbo is a private company categorized under Motor Generator Sets, Automotive and located in San Dimas, CA. Our records show it was established in 2008 and incorporated in California. Current estimates show this company has an annual revenue of less than $500,000 and employs a staff of approximately 1 to 4.
