The dealer will only have a general record if you've been going to the same dealership since the trucks original purchase back in 91... and since we know that's not going to be the case I would have them check the prom id... at least that's my understanding of GM records considering the local dealership couldn't pull up any history on the typhoon I brought up from washington... Maybe it's different with TSB's and campaigns.? just to be sure I'd also have them give you that number with you standing there so you can check that number against your own list...
I would say to check and make a print out from
http://www.syty.org/old/promguide.html
unfortunately that was taken down
Falco has the list posted on his site at tragacs.com
There were different versions under different part numbers representing the different EPROM versions. The following table is from the old SyTy.org site.
Scan ID Delco ID Part Number
3051 AXXA 3086 16163085
3961 AYBM 4052 -
3961 AYBM 4053 16164052
3971 AYBN 4175 16164174
8581 AWXJ 9137 16159136
831 BBZA 1576 16181575
841 BBZB 1580 16181579
0 DOAC 6502 -
The 'BBZB 1580' should be the current EPROM for our application. The EPROM is a 27C128.
4) Chip itself. Sys with VINs lower than 1522 were subject to
a service campaign which called for a replacement MEMCAL (PROM).
1-800-462-8782 and ask if your truck received campaign #91036 for idle
surge.
