regular 4.3 and syty 4.3 block differences?
MikeRenz
not stock
the reason i ask is that I went to connect my coolant return line from the turbo to the block this weekend.....and the connector for the line was a lot bigger than the port in the block. Are these ports different on regular blocks compared to syty blocks?
Also, I didn't try to connect the oil feed line for the turbo yet....does this port exist on a normal 4.3 block?
bezerk
About the coolant line for turbo: Don''t know.
Feed line for the turbo (oil). i believe that with an org. SyTy block, this one comes from the side where the turbo is connected.
With every other block (also the replacement blocks, wich is almost the same as an org. block) the oilfeed-line comes from the otherside where the oil-filter-adapter is mounted, this one is for an old fasion oil-pressure gauge.
Rene
MikeRenz
not stock
i know that the oil FEED line isn't on the passenger side of the block. The oil drain/return line is though. I've been told that all blocks have the oil feed port.
I'm just very confused on this coolant port. I know i can just get adapter fittings to make it work, or make a new line....but i'm just trying to figure out if my block is original.
MikeRenz
not stock
Sy769 said:
Where is your original block?
Should be a adapter fitting that screws into the block.
Do they all use an adapter fitting? Or are you just saying as a fix.
I thought i had my original block....and I might - just not sure becuase of this stupid fitting.
Captain Morgan
Moderated User
they all have the adaptor fitting. Its needed cause the coolant line is a flare fitting, so the fitting the screws into the block and a Pipe - Flare fitting.
bezerk
Aslo have 2 engines, none of them is original. but both have those nodulair bearings, and the numbers are different.
and also have that cooling feed line.
maybe you could call to a GM dealer, give them your engine number, and they could tell you if it is an Z engine code.
I just took a look at the cooling suplly line.
with both engines the supply line comes from the Lowerintake, wich i believe are specially made for SyTy's.
Don''t believe that there are still alot of the REAL original engines left.
Rene
