Regulator?
92 Ty 1173
Before somebody says "SEARCH", hear me out. All I want to know is if our trucks use the same AFPR that an LT-1 uses. I just got an Areomotive AFPR part # 13106 for an LT-1 because there isn't a listing for sy/ty's. I figures if most GM's use the same fuel pump that there is a good chance the regulators are the same.
James Thomas
"NO CLASS"
Re: Regulator?
Same as a Buick GN. Don't know about the LT-1 cause I don't like'em. Search sucks and misses a LOT, if ya know the anwser, be a brother and spill it. But................. I do agree that you should at least make the effort to try and find it on your own.
__________
James
92 Ty 1173
Re: Regulator?
Well I'll find out saturday night, garage night. I have a walbro 255/hp,pressure reg,motor mounts, and lower exchanger fans to install. Should be a full night of cursing, throwing tools/old parts, and beer. I'll let ya's know if the LT-1 reg works. Your right the search does suck, I tried that first and saw nothing that helped me. Sometimes it works like a charm and others like crap.
Re: Regulator?
from aeromotive.com:
hese LT1 specific regulators are fully adjustable from 30-70 PSI base, plus 1:1 vacuum/boost reference. Two models are available for GM LT-1 engines. P/N 13106 fits '92-'96 LT1 Corvette , P/N 13107 fits '94-'97 LT1 F-Body Camaro/Firebird and '94-'96 Impala SS.
Aeromotive's GM LT-1 Regulator was developed with LT-1 engine specs in mind to help your car perform at its peak. It is a true, CNC machined billet regulator, offering:
Fully adjustable fuel pressure from 30-70 PSI.
Vacuum/Boost Reference on a 1:1 ratio.
1/8" NPT gauge/test pressure port.
Stainless steel spring, custom-designed for precise fuel control.
CNC-machined aluminum seat and ports.
P/N 13106 may fit other GM/Saturn products that use the same regulator configuration as LT1, including the GM Ram-Jet 350 EFI Crate Motor.
P/N 13107 may fit other GM/Saturn products that use the same regulator configuration as LT1. Also reported to fit some Edelbrock EFI fuel rails.
If it was designed using LT1 specs it might work, just not as good.
92 Ty 1173
Re: Regulator?
Why would LT 1 specs have ill affect on perfomance? Adjustable with boost port is all you need right? What would differ from the one from RPM?
92 Ty 1173
Re: Regulator?
Yeah, it don't fit. Ordered one from Turbotime. I only found ones from the dealers on here. The big companies don't make one.
