Relays
onlyav6
Can anyone tell me what this other relay on the back firewall is for
DaveP's Ghost
Well-known member
That is not the OEM style relay, but it appears that it is plugged into the "Boost Control" relay connector. The boost control relay has 2 pnk/blk, 1 dk green, 1 orange wires. << This is how you confirm it that this is what it is. Wire colors. The empty relay connector in the pic is for the intercooler pump.
The relay is normally closed, IGN power (pnk/blk) on terminal 30 is passed through to the orange wire on terminal 87a. The orange wire is the (+) side of the waste-gate solenoid. The dk green wire goes to the lower heat exchanger probe. The idea was that if intercooler fluid level got low, the relay would open, and limit boost to 7psi base. The dk green wire also goes to the Low Turbo Coolant light in the instrument cluster.
To make these two things work requires a module that interprets the resistance at the probe, and if out of range by "low coolant", the module grounds the green wire to energize the relay which removes the (+) to the waste-gate solenoid and turn on the light. Well, somehow or another this module was never incorporated into the trucks when built. So as-delivered, neither the relay or the light function, and never did.
In 2000, I wrote an article describing how to wire the module to make these things functional. It was in The Vault, which was not reinstated when Keith updated the site. I had the part numbers for the module and pigtail from a C4 Corvette which worked well in the SyTy. I converted two of my trucks, and one is still in my yard, and the light works. No way are the parts to convert it still available, nor is it a big deal that they don't work. If you still have a waste-gate solenoid, with the key ON, check that there is 12 V at the orange wire at the solenoid. If = YES, that's all you need to do.
I know, TL;DR. But now you know the full story. Not many of us that were figuring this stuff out 20+ years ago are still around. Not too far into the future, these tid-bits will be lost forever.
onlyav6
Thank you very much for the input now, I know what that's for the guy who owned it before me took out the liquid intercooler, and put in a front larger intercooler.
RealFastV6
@jb_and_his_coffee
Here ya go Dave...
OK, a few weeks ago we talked about how the low turbo coolant light doesn't
function as delivered OEM. I did some research, and installed the
low-coolant module as used in 88 Corvette. The light now functions as
intended. Plus there is a 2 second 'bulb test' on power-up, similar to the
antilock light.
You will need the following:
P/N 22533547 Module 17.00 wholesale
P/N 12117360 Connector Pigtail. 23.00 wholesale
I located it next to the fuel pump relay. I secured it with a tie-wrap to the
FP relay. I made the wire connections in the big harness that goes over the
top of the brake booster. The installation took about an hour, not including
the 'research.' I've done that for you.
The module and plug pins have letters. Connect as follows:
A Hot with Ign. Splice into the Pnk/Blk wire that goes to the A/C relay
that's next to the FP relay.
B Not Connected
C Ground. There is a splice in the black wire that the 3-wire plug to the
IC pump and sensor goes into. I made this connection here, and
re-taped the splice.
D Not Connected
E&F Cut the green wire on the engine side of the 3-pin connector.
E Is the output to the light. Splice 'E' on the green that goes towards the
engine.
F Is the sensor. Splice 'F' to the green that goes towards the sensor.
The wires on the pigtail are all white. I got the polarity backwards on pin A&C,
and ruined my first module. Double-check the connections before turning
the key on.
Assure proper operation as follows: Turn key to ignition. Low turbo coolant
light should illuminate briefly, and go out. Leave key on. Disconnect sensor,
or 3-pin connector. Light should come on, and boost cutout relay (over
distributor) should click. Reconnect sensor, light should go out.
Easy project, and for 40.00 your low turbo coolant light will actually be
functional. If anyone needs assistance with this, I'll be glad to clarify if
needed. Just let me know.
DaveP
