Remote ECM Access
WyoSyclone
Well, since I started tuning my truck with Code59, my ECM has been laying on a pile of towels on the passenger floorboard. Like this....
Well, people have been wanting to go for rides and I was afraid of something happening to the ECM so I decided to take a suggestion from Dig and use some parts off of Craig Moates website to give myself remote access for tuning.
Here are the parts I used from http://www.moates.net/
... Of course I already had the G1 chip carrier/bypass board
What I had to purchase was...
1) Extender 1.0 for $20
2) 28 pin DIP socket for $2
I didn't take a picture of mine, but this is a picture off of the Moates website of the 24 pin version. Socket is pointed out by the Red line. The socket serves to move the cable connector up out of the ECM reducing the strain on the connector and cable. This also isn't our '749 ECM, so pic looks a little strange.
3) 18" EMUC2818, 18" ribbon cable for $9
I took the ZIF socket off of the G1 adaptor and put it on the Extender 1.0, plugged the cable into it, then hot-glued the entire assembly to the bottom side of a small plastic case I had laying around....
When working with Craig's cabling and sockets, the red wire on the ribbon cable always goes towards the #1 pin side (the side of the chip with the little half moon cut out of it).
So, I plugged the assembly into my ECM, put two pieces of small convoluted tubing over the edges of the ECM case so as not to cause abrasion to the cable, put two furniture pads on the ECM case to space the cover and provide clearance for the ribbon cable (see pic #1), then screwed the lid back on to the ECM.
Now comes putting the ECM back in place.... Son of a (*&(*^%!@, F*&$K'ing wires!!!!!
OK, that wasn't a very easy thing to do for a 6'2, 222 lb 50 year old with big hands laying on his back on the floorboard!
But, when all was put back together I have VERY easy access to my Extender box so I can replace chips or hook up my Ostrich!
Snap the lid back on, and it's all safe and ready to drive!
And, I got my passenger footwell back so I can scare people with rides in the Sy! :D
Oh, whenever I have to stick a box back behind a dash and the space is really tight, I always worry about grounding a wire out against a sharp piece of metal. Whenever I go to hook the battery back up I use a fuse holder with a 1 amp fuse and connect it between the battery negative and battery. If the fuse blows, there is probably a grounded wire. This trick will save you from frying a wire harness and/or a possible fire.
I still need to go back and get some nice screws (black) for the plastic box, but, all-in-all a very worthwhile addition for those of us who like to tune all the time.
Thanks Dig for the suggestion!! Hope this inspires or helps someone else.
...Rob
mattw
Re: Remote ECM Access
I tried something similar a while back but those extender boards weren't available yet and it worked but did funny stuff..
I'll have to pick up an extender board.
-Matt
WyoSyclone
-Matt
Hi Matt,
The Extender 1.0 board has an active circuit on it which buffers and amplifies the signal to take care of the length of ribbon cable. I was a little worried about interference, but so far on a short ride it seems to work like a champ!
TYTILIDIE
METH HEAD
WyoSyclone said:
Could it be classified as tuning "Bling"? ;)
:rotf: Aaaaahhhh yyyeaaaahhhhhh!!!! If didnt spend so much time putting mine in the glove box I probably would go for that set up. Or if I had any money right now.
leroy
Very nice how-to. I vote to send it to the "vault", or make it a "sticky".
Jim
