Remote Intercooler Pump?
Has any one ever remotely located their intercooler pump? Don't know why I thought of it. Some one must have tried it at some point in time. Would there be any benefit? Pictures?
Ian Turgeon
Cascading Inspiration
Re: Remote Intercooler Pump?
Keeping the pump at the bottom of the system will help keep air out of it, however locating it elsewhere should work just fine as long as all the air is out of the system.
I believe the ATR kit had you mount the pump on the fenderwell. Really whatever fits your needs will work fine.
TYTILIDIE
METH HEAD
TURBOTYPHOON69 ( Abe ), has his mounted on the fender well. I think its a pretty good idea. It sucks having to drop the HE down to work on the pump or R&R it.
Mike
turbodog
I run a dual pump setup. Both stock-type centrifugal pumps (Jabsco). One in stock location, the other behind the radiator support, below the pass side headlite, below the vacuum ball. The 2nd pump pulls from the upper IC and pushes into the aux CCHE in front of the radiator.
I got to thinking about it because I have a Jabsco jsut sitting around not being used and I thought I might as well put it to work.
JKsSyclone
I have my Surflo mounted under the Sy on the crossmember. I have a homemade ice tank mounted under the bed behind the left rear wheel. The pumps flows great and i have low intake temps!
TYRODD
My ass. Look at it.
I mounted my shurflo to the driverside front bumper support, using large hose clamps (4"). I also made a shield for it since it sits directly in front of the wheel.
