removing charcoal cannister
canadian
sy in progress
OK, the fittings on the charcoal cannister have been broken for years and were rigged to kind of function. I would like to get rid of the cannister for a little extra room under the hood.
I have seen the vacuum diagram with the line coming off the throttle body, through a check valve and then to the cannister. The other line from the cannister goes to the tank.
I'm thinking of running the line that comes from the tank up the firewall next to the vent line by the brake booster and finding a vent fitting like the other line has.
For the line coming off the throttle body, can it be removed and the fitting left open, or does the fitting on the throttle body need to be pluggd with a vacuum cap?
Any drawbacks to removing the cannister?
sytyguy
Moderated User
No side effects. Mine's been off since '99. Some have complained about a minor fuel odor when sitting still, but I have never had a problem on either of my trucks.
Hood
canadian
sy in progress
appreciate all the replies. so just a vacuum cap needed on the tb and a vent cap on the tank line?
93ty475
would the mentioned fuel smell be coming from the filler cap area? i smell fuel when the truck is sealed in the garage for more than a day...no charcoal canister here...and no known fuel leaks...can't imagine where else the smell would come from...
edit: install a canister by the fuel tank maybe? iirc. the vacuum connection for the canister doesn't have very much suction to it anyway...think it would remediate the odor w/out the vac line attached?
#2875
built, not bought
i went to [insert local auto parts store here] and got a k&n breather style filter from the import section for $6. it might look cool to some people but i stuffed it under the booster. anyway i never smell gas. i left the bracket on to hold my pcv oil catch can.
#2875
built, not bought
well i noticed that (before i changed heads) i was getting a lot of oil sucked into my intake through the pcv system (blow by?). it was so bad it saturated my phenaulic tb spacer in about 2 hours. so i fabbed a simple catch can to go inline between the rear pcv and the tb vacuum port. i purpously made it about the same OD as the p.o.s. char canister so it would fit in the same spot and use the same bracket. FYI: greddy makes a can for about $100 but i'm not sure about that. did i answer your question?
#2875
built, not bought
well first i went out into the shop and found a scrap piece of thin wall aluminum tubing that would work, faced it to length and turned a counterbore on each end 1/2 the thickness of the end caps i was using so the end caps would sit in the bore and give me a weld detail. then i waterjet 2 baffles that locked together kind of like the cardboard that separates a new set of lifters. i also put 2 tabs on one end for retaining later. the baffles went into the tubing about half way. then i waterjet 2 end caps. one was just a disc (bottom). the top had holes for the tabs on the baffle to come thru and 3 round holes for (3) 1/8" aluminum couplings. 1 in, 1 out and one for a drain pitcock. then i tig welded all that shit together, bead blasted it and screwed in my fittings. i used straight barbed hose fittings which worked with a little effort but in retrospect i should have used 90 deg. fittings because i still have the stock airbox. oh yea and i did a high tech pressure test (mouth, finger and soapy water). i also wire tied a piece of silicon rubber (because i had some laying around) all the way around it so it wouldn't rattle around.
