Removing O2 sensor.
THEMADTYPH00N
Anyone have any tips on getting the O2 sensor out? I'm having trouble breaking it loosing. Plus I'm having trouble getting the wrench around it because its in such a tight area. Thanks for any help you guys can offer.
Falco
Justin,
Two tips. Try it why the exhaust still hot. It will come out much easier. Use a glove. If it still don't want to come out, there is a special O2 sensor wrench, which you could buy at most auto chain stores. You can attach your 3/8" extensions to it.
HTH,
Coloty
Trying with the engine hot is good to try. I used a O2 socket wrench and 10" 3/8 extension with a universal joint. This allows you to get the socket on the sensor and the hook up the universal and extension and it barely clears the upper intercooler reservoir. The 10" extension allows you to put some torque on the sensor as you have plenty of room up above everything (upper cooler res). Good luck
Loeryder
Be very careful using an O2 socket.
It is a deepwell socket with a slit cut in teh side to accomodate the wires.
My O2 was soo tight or I put soo much torque on it taht the socket spread open and rounded my O2 off.
I used a hose clamp around the socket to hold it closed and used a 1/2 breaker bar on a 10" wobble extension, came out but left the threads in the DP.
Break it loose at each oil change and retighten to be sure it will always come back out easier. Hell some folks are changing them about at every oil change.. lol
Coloty
Take Jas' advice. He warned me about the bolts on the end links of the sway bar and I was extra careful and still striped the MOFOs out. I might start breaking it loose at oil changes. Thats a good tip. I wonder if the anti-seize that comes on it is enough? Anyone add more to it when installing?
smeagol
I had a nasty one once, we took the fenderwell out, jacked the truck up, had a wrench on it, a cheater bar, and 2 people. This was after spraying the 02 with some anti-seize stuff. I think we almost accidentally took the downpipe out too ;)
The 02 sensor lost. I refuse to be beat by any car part. If it does look like it's going to win, I end up beating it... severely. The part usually gives up or is destroyed; thus I win by default. Just ask my last 3 laptops.
Daron
My original O2 was tougher than one extension and a breaker. Snapped the extention and bent the breaker bar. I finally just used a torch and heated the O2 bung up, then it came out super easy. The one I replaced it with has anti seize compond on the treads, and for good measure I introduced it to Mr Torch prior to installation....
Loeryder
jwaller said:
it you are changing the o2 then cut the wires and use a regualr socket.
In my case it was cut the wires and then beat it with a hammer, then use a Metrinch socket on it.
Anyone see the infomercial? I thought it was another BS product (It grabs bolt heads by the "Wall" instead of the "corners" like traditional sockets. but I have found myself using it on a lot of things lately, fits both metric and sae pretty well.
Craftsman U Joints are the shit, don't even try it with off brand, I broke 2 of those and my first wobble extension trying. That 1st O2 socket I spred open was whatever off brand Autozone sells. they gave me my money back And I went and bought a Craftsman. just a big hassle, get the good shit first.
As for the bolts in the sway bar, drill them all the way through, use a longer bolt and put a nut on the upper side of the control arm. I ended up pulling another bolt out trying to autocross my truck at GB. And that hows Dustan does the sway bars his coilovers, long bolt with a nut, but thats a diiferent story altogether...
<Rambling outside to clean my truck in teh sun MODE=ON>
<Mumbling Syty something or other walking out the door with Smirnoff in hand....
Coloty
Jas' thanks for the tip on the long bolt and a nut for the swap bar end links. If it jacks up again I'll do that for sure. I was even entertaining having someone tack weld them to the a-arm.
THEMADTYPH00N
Thanks guys. This time I did it with the truck hot instead of letting it cool down. Couple a hard turns and it came right out. Datamaster should be here in the next couple of days so I'll probably needs some one to look at that after I make some runs. Later
Ian Turgeon
Cascading Inspiration
I know mike and christian had a serious issue with mikes o2.. truck had somewhere around 150k miles and probly the original o2.
spread the o2 socket right open, put a hose clamp on it, didnt help, still overpowered the hoseclamp/socket.
from what I remember they ended up destroying the o2.. maybe the bung came out from the downpipe.
at any rate, they ended up having to weld a new bung in (an autozone hack a fix.. a "spark plug spacer" with the end cut off makes for a great new bung.)
Pittman
I got pissed and got the BFH2000 after it! :evil: !!! I figured oh well I guess Ill just order the PTE setup tomorrow either way its outa there!. That POS faught hard even after I got the downpipe out of the truck (yeah even after the pte setup was on ther I couldnt let it win). Got a 3 foot 1/2 inch drive breaker bar after it and it tore the bung out and kinda tweaked the wall of the pip. I was so impressed by the fight that little bastard gave me I just had to keep it. So it now resides in the top of my box as a reminder to all man kind. I see it as a kind of a hick, redneck momento: no mater what the problem with lots of beer, some drunk friends, and enough force you can overcome. Oh yeah just before it broke the bung out and through my 250lb ass on the ground I said "hey watch this!"
