Replace FPR?
WillBoost4Food
Red Ty Supremacy
So I did my vacuum line replacement this week and when I was replacing the vacuum line from the FPR into the T connector (one goes into back intake, other into the black sensor on the drivers side) when I removed the vacuum line fuel just spilled out all over from inside the vacuum line.
Lately I have been having some idling/acceleration issues and I was thinking this is probably the culprit. I never had fuel spill out of the vacuum lines on other cars when disconnecting the vacuum line from the FPR. I am thinking the FPR is dead...
I want to replace it with something close to stock, but if there is anything out there aftermarket worth getting over stock replacement I am open to ideas.For a a stock/aftermarket replacement one, which one do you guys recommend?
WyoSyclone
Re: Replace FPR?
Yup, the diaphragm is bad... I use the Accufab adjustable piece and it has been perfect for 3 years now :D
WillBoost4Food
Red Ty Supremacy
Re: Replace FPR?
Yeah thats what I figured was the case. I looked at the accufab website and the only one they have listed for our trucks is for the Syclone ( I have a TY). I am assuming the two are the same?
WillBoost4Food
Red Ty Supremacy
Re: Replace FPR?
Sweet I will just give them a call tomorrow. They have it for $150 which considering a stock replacement at Autozone was like 80-90 I might as well just get a high quality adjustable piece.
Thanks guys.
Mtn Z
Re: Replace FPR?
Yeah, the Accufab FPR is the way to go over a stocker. It's easy to install and adjust.
