replaced o2 for maintenance and now...
SevenT6Vet
getting check engine light 44
I've had problems starting it, and i've replaced EVERY ignition component (except distributor itself).
I've never had a check engine light, so i figured i would throw in a new bosch o2 since my data file showed some screwy o2 readings.
i pulled negative on battery for 10 minutes, started it up, and idle was surging, but not cutting out on me. Took it out and noticed some hesitation. went 1 mile and CEL came on, then went off after a 1/2 mile. then back on. vehicle was stumbling under constant throttle at 55 mph (but would never die completely).
looks like i have a fuel issue, so let me explain what i've done there:
replaced fuel filter fall 2010, has less than 500 miles on it.
put fuel pressure gauge on rail last year, held 43 with key on. check valve holds after key is released, no drain back. at idle, gauge fluttered b/w 40-45 (maybe from vibration).
vehicle is still a bitch to start, but always starts after ~20 short (1-2 second) cranks.
ngk plugs/wires/brass cap/rotor/coil/gm ign module/bosch o2 are all new.
truck has 92k miles.
FPR is original, but is not leaking any fuel up through vac line.
fuel pump, to my knowledge, is original.
truck drove fine last week with old o2 on there, no hesitation or stumbling or CEL. truck has been difficult to start since i've bought it.
Re: replaced o2 for maintenance and now...
I'd swap out the pump just for peace of mind. I had a new pump give me starting issues on my '01 Blazer. Ever since install, I had to crank it a few times before it started. I wouldn't put it past the pump to be causing this.
