Replacement cladding
chuckyuen
The cladding on my syclone is starting to deteriorate due to the sun and UV here in Hawaii. Several pieces are starting to crack and a lot of the mounting tabs are starting to break off. Where is the best place to get a replacement set of cladding? How much should I expect to spend?
I've also been in contact with a guy on eBay who sells a replacement set made out of fiberglass. What do you guys think about this? He wants $3750 plus shipping for a full set. Is that reasonable?
Thanks for the help.
2500avalanche
Well-known member
Re: Replacement cladding
I would fix the mounting brackets using 2 part epoxy. There are a few people with OEM sets that are new. Let me make a call to Mark. SY/TY cladding guru!
Jeff
yar probably has what you want/need but I would repair the cladding you have and get it painted personally.
V
Whatever you do, don't trash your damaged cladding. I might be interested in buying your broken parts.
chuckyuen
Thanks for the advice and help guys.
Jeff, let me know what you hear from Mark. Thanks for the help.
V, if I do sell my old cladding I'll let you know first.
chuckyuen
Thanks Jeff. I guess 2 part epoxy becomes my new best friend. What kind do you guys recommend?
IMMensaMind
I have a complete set of Typhoon cladding that I bought - way back in the day - from a poster who I understand posts here (Ray Moore?). I had to do quite a bit of "massaging" to get it into shape, and my "massaging" isn't quite finished (my project never did happen). I was under the impression that the parts were in better shape than they actually were (and I am OCD about that kind of stuff). I spent a ton of time shape-sanding them; repairing nicks/holes/waves/etc. These parts are nearly all paint-ready (and they're straight now, and structurally sound with all tabs).
How different is the Sy cladding from the Ty cladding? I have everything - including bumper back support parts, aluminum rocker cladding support parts, core support and grille.
I think I'll list it here, and see what bids I get on it...
