Nuttin really special about it. Best to change it while it's still somewhat hot. The heat will loosen the threads a bit and make it easier to break loose. The 3 wire connector usually runs under the upper IC, but just trace the wires from the sensor back and unplug it (before trying to remove the sensor). They make a socket with a slit in it (for the wires to slide into) for removing the O2 sensor, but you may can get a 7/8" wrench in there and break it loose as well. Also, make sure the new one has thread lubricant on it before installing (or else it'll be hella hard to get that one out the next time around).
That's pretty much it. 20 minute job.....tops.
Hood
