Replacing Carpet in the Syclone
sytyguy
Moderated User
I've searched and a lot of the results are aging (most say go with RKK), so I thought I'd see if anyone had any advice. I'm looking to replace the carpet and sound deadening material in my truck. Here are my stipulations/questions:
- I need it to be the correct or close to the factory color.
- I need it to be molded and fit well.
- I don't want to spend a fortune. I'm willing to compromise to some extent.
- I want it to be a very good type of carpet. If there's a newer kind (tuxedo, truvette, etc...) that looks better, lasts longer, fades less, vacuums easier, and is available in the correct color, I'll switch (if cut pile is still good enough, then I won't).
- Is dynamat/brown bread still the best alternative for sound deadening?
If any of you have some good suggestions, please share them. I was looking at Auto Custom Carpets and Stock Interiors, but haven't seen much info on them around here.
TIA for any help.
Hood
SyTyJedi
Jedi Council
Re: Replacing Carpet in the Syclone
I'm using B-Quiet Extreme in my Ty, which I've heard is the same as the Brown Bead stuff just under a different name. It's about $1/sq ft on Ebay, which isn't bad IMO. Look at what Dynamat is charging these days for their small pieces of deadener.
I'm doing the whole Ty with this stuff and I can tell you that the difference in just tapping on the sheetmetal is unbelievable. It will be as quiet as a new luxury SUV and still go as fast as a rocket ;)
For those cocerned about weight, I think the shipping label said that 100sq ft was about ~30 lbs.
Ian Turgeon
Cascading Inspiration
I had the rk stuff, was very good. Maybe you could find out who he got his carpets from? actually that would help us all out.
Honestly if I could get a carpet style that matched the sti's carpet I'd jump on it.
sytyguy
Moderated User
Tyler, appreciate the info man. I'm gonna check out that B-Quiet stuff.
Ian....I'll see what I can find.
Pete....did you get the black? If so, does it match the OE color pretty close? That's a really good price, so I may hafta jump on that if the quality/color is really nice.
Thanks a bunch guys. This made it really easy.
Hood
Merk
RK Kustom used ACC Mats
Auto-interiors.com use ACC Mats
I'll post the Sound deadner I used. It was the lightest available at the time, and price was relatively competitive.
I'll send you a PM when I find the info.
epix
Typhoon
yea, i got the black, it was darker than the stock. But in the end it turned out better than stock IMO.
their carpet is really high quality. very thick and padded.
DOMN8R
NASTE Member
I don't know much about replacement carpets, but I've heard the ACC stuff is better quality and fit than the other brands.
I have put over 100 hours of sound deadening into my ty, including many layers on the firewall. I like Raamaudio (http://www.raamaudio.com) products the best overall. The new BXT is phenomenal for the price and ensolite was great and easy to stretch and work with. Ensolite is probably my favorite sound deadening product. It is EXTREMELY light, which makes it a natural choice for a sy/ty. Depending on your goals, you may not want to use ensolite. If you do use it, I would sandwich it between layers of BXT. Just remember it's an absorber, not a replacement for a damper like BXT or dynamat extreme etc.
Depending on your budget, Second Skin products (http://www.secondskinaudio.com) are also definitely worth a look, for something slightly better than raamaudio's products at several times the price.
Go visit S-Series.org and do a search.
I remember a fairly big write up on sound deadening materials. One guy (I forget who) did an experiment with them and posted alot of opinions. I'll go see if I can find it when I finish catching up, if not you know where to look.
Hope it helps.
TT350
Manufacturer
On my 93 S-10 the OE manufacture label is
on the backing under the drivers foot well.
It has the part # and color.
Chris
