Bear with me a bit here... I have checked all, and actually repaired some, connections between the ECM, the narrow band output from the PLX, AND the wide band output from the PLX. I've done this numerous times over a period of a week actually just to eliminate the tiredness/distractions factor. The one thing I found that I could actually put my finger on was the ign switch. Jiggle the key and I'd get voltage fluctuations at the ECM so I changed that as well.
Look at this DM and notice how randomly the o2 mv and the wide band go lean and back instantly. Later in the run I do a boost launch and things seem normal if a bit rich. I could put up a long DM of just driving down the street and it shows the same momentary swings. The actual AFR gauge on the panel follows, goes to lean, when this happens as well so I don't think it's DM or the ALDL cable.
What's going on? I'm totally frustrated with this. I wonder if the wide band sensor itself has gone bad. It's mounted it the stock location on a JSM down pipe. PLX instructions say to mount it further down but I and others have asked if the stock location is OK and the answer has been yes it works there OK with a stock build (stock inj's and stock turbo) which I have.
http://www.sonic.net/~donpris/AutoLog_394.uni
Any help/ideas very much appreciated.
