rocker question
NecroWolf
lost marbles member
i keep seeing offset jessel shaft rockers for sell on ebay for v8, they look like each pair of rockers is seperate. would these be adaptable to my pontiac heads? anyone got any idea? i hate to spend the money on them and then they not work.
THEMADTYPH00N
Re: rocker question
Even if the valve spacing & bolt pattern was the same, the stands the rockers bolt to would still be 1 cylinder too long.
NecroWolf
lost marbles member
Re: rocker question
hmm okay, the ones i'm looking at aren't on a single shaft, would that make a difference
Windedv6
Ty n 10s
Re: rocker question
Call Jezel. You will find them helpful. The Bowtie and the Pontiac/Brodix heads are different. Some of the offset rockers are the same but the stands are different. There are numbers on both the stands and the rockers. If you can get those numbers and call Jezel they will tell you what they fit.
John
