rod bearing clearance
Re: rod bearing clearance
Assuming the 4.3 engine, rods are .0013 - .0035
Ls10
Yeah stock 93 ty rods. Hmmm I searched high and low on here. Someone said .001-.015. Google says .028-.038. where did you find those specs?
1991 GMC Light Duty Truck Unit Repair Manual. I checked the Supplement and it's the same.
To save you the trouble mains are:
#1 .0008 - .0020
#2 & #3 .0011 - .0023
#4 .0017 - .0032
Odd that there are 3 different clearances but there is a reason. I just don't know it. Interestingly the main journal size range is also different for 1, 2&3, 4, so maybe that's it.
Figured you'd chime in here Dave, thanks. Here's the long technical version of what Dave is talking about. This will probably raise a few eyebrows but I have seen where -one- .002 under shell paired with a std shell can be used to fine tune bearing clearances. Requires purchase of two sets of bearings though.
www.kingbearings.com/wp-content/uploads/2014/10/optimization-of-clearance-engine-professional.pdf
BTW the little tab on the shell is -not- there to keep the bearing from turning, only to locate the bearing side to side. Bearing "crush" which, in effect, makes the bearing a "press fit' does that. Some newer engines don't even have a tab as the bearing is placed by robots.
