ok people what rods are you using in your bowtie builds? 5.7, 6.00, 5.8850
that would depend on the stroke of the crank!
We use 5.7 rods on the 3.75 crank. The 5.85 and the 6s will give you less compression height on the piston (because of the piston dish), if you want to stay with an 8.5:1 - 9.5:1 compression ratio. If you are doing flat top pistons then go with 5.85 rods, but your compression ratio will be in the 10:1 range or higher depending on the head chamber size. Cometic makes a .051 (vs .040) which will help some to keep the compression down.
John
John
if i used a 5.7 rod won't that make a top heavy piston? i have the bow tie 051 block deck height is 9.025. with billet 3.75 stroker, I'm aiming to a 9:1 i was unable to get this far with my builder as, he gotten sick and past away. i just got my stuff back. r.i.p Don!!!! also i'm going for street strip set up
What is your bore size and head chamber size?
