roller rockers 1.6
IGottaSy
Can they be used on stock head/cam/push rod/spring/stud???
I am looking at comp cams magnum series rocker.
sytyguy
Moderated User
Re: roller rockers 1.6
Yes you can use them just make sure they're self-aligning. LMK what PN you decide on and I might be able to save you some money.
sytyguy
Moderated User
My push rods hit the heads with the 1.6 rockers. Had to drill out the holes FYI
Interesting. Mine cleared fine with magnum rockers on LB4 heads (mid-year Syclone) and L35s (when I upgraded years later).
IGottaSy
Makes sense. the push rod is moved .1" away from the stock position due to the longer rocker. I have a set of SB Chevy magnums but just noticed they aren't self-aligning. Either add plates + studs or trade? buy? :-(
BoostedSUV
Was it with a stock cam? Higher lift cam might make a difference?
Comp 412 cam with comp 1.6 roller rockers. The push rods rubbed on the push rod holes. Probably wasn't causing issue but I did have to open them up.
