romulator install question
vortecfiero
looking for pics
I searched and found lots of pics of a Moates/romulator setup, but I didn't see any pics showing how this setup plugged into the ecm or even just a moats in an ecm
sytyguy
Moderated User
Well, the romulator plugs into the adapter (Moates, custom, etc....) like any eprom would. The Moates adapter is 32 pin, so you'll need to offset the adapter towards the "rear" by 2 pins (per side). Pin 1 is as listed on the adapter carrier (it actually lists pin 2, but pin 1 is opposite pin 2, and when offset 2 pins, it becomes pin 5 on the carrier), and obviously the red wire on the romulator cable is pin 1.
If using the Moates G3 adapter, remember to set the jumpers to 29C256 and the switch to either F or 0 (although it should work in any position). Also, I had to remove the blue EPROM cover to fit it into my ECM, you may have to do the same.
Anywho, here are a few pics:
http://www.tuckerautopartsonline.com/images/G3-1.jpg
http://www.tuckerautopartsonline.com/images/G3-2.jpg
http://www.tuckerautopartsonline.com/images/G3-3.jpg
http://www.tuckerautopartsonline.com/images/G3-4.jpg
http://www.tuckerautopartsonline.com/images/G3-5.jpg
http://www.tuckerautopartsonline.com/images/G3-6.jpg
HTHs
Michael
vortecfiero
thanks, those are some of of the pics I was talking (typing?) about
and I what I was looking for was a pic of how that plugs into the ECM
It's my belief that a 28 pin prom socket (to raise some height to attach
a 28 pin zif or 3M socket) on the prom carrier would probably work with
no moats adapters.
also I'd like to see pics of the different Moats adapters for our application in use
the reason being, my ecm will be very visable and Im thinking of creating
a new case for it similar to the current stereo amps for a MONSTER ECM
hmmm... wrinkle finish red and polished aluminum with huge heat sinks and a big fan !
93 TY 2185
sytyguy said:
Hope these help. FWIW, I am creating a page on how to setup up the Romulator physically as well as how to get started tuning with it (via Promgrammer and Tunercat RT).
Prolly have the page done by Friday.........just need to get my Romulator back from Waller (hint...hint.....John :wink: ).
Hood
I would love to see this Romulator Tunercat RT for beginners 8)
Thanks in advance for doing this Michael.
