romulator problems... i cant catch a break
TurboJunk
questionable
I finally started my truck last week thursday, after doing the timing i installed the romulator and it runs like CRAP!... its not the bin file its thats the problem. i cant get the check engine light to work when i take the romulator off the check engine light does its job, but with it plugged in NOTHING DOING !
CAN ANYONE shed some light on my issues....
TurboJunk
questionable
Re: romulator problems... i cant catch a break
well after reinstalling the bin in the romulator it idles , and drives but boost is not happening? can my bin file be wrong? or a problm with my romulator?.....
anyone with a suggestion?
ashman
are you emulating the chip you removed? i would try that first and get it to work with a known good bin. you also have to make sure you have the bin loaded into the correct memory location of the romulator. don't load the bins with the romu connected to the ECM.
btw, what application are you using to load the bins?
sytyguy
Moderated User
Have you verified correct pin orientation on the adapter?
Have you verified proper piggy-backing?
What adapter are you using? modded stock chip? G3? Ultimate?
How does it run without the romulator?
I have seen both of these situations cause problems of this nature, with incorrect piggy-backing being the most common. A lot of people think you plug into the eprom side of the stock memcal, but you actually plug into the ESC circuitry side.
Hopefully it'll be something simple.
Hood
TurboJunk
questionable
well im using the G1 adapter from MOATES.net i installed it actually the way they show it on the website i know which part of the chip your bypassing its the one that says delco on it not the colorfull looking on thats bigger next to it. the way i loaded it was looked it up to the coputer loaded the file using {Pocket Programmer (PKT_ROM)} then installed everything on my ECU.
without the romulator the truck doesnt run cause of the injectors and map sensor and other mods. here are some picks of how i have it hooked up , let me know what you think
ashman
your connection looks correct. i'm guessing, from experience, that the loading of the bins may be the problem...this is the instructions i used that seemed to work
Set com port until the message "looking for pocket rom" goes away.
Click on the "pull hard button" should read "PULL SOFT"
Set Eprom size to match bin, 27128 for 16 bit, and 27256 for 32 bit.
Then load buffer
Send buffer to Rom
Verify Buffer
ashman
sounds like "limp home" mode when the ROM is plugged in
ashman
did the truck run before the romulator? are you using a known good .bin?
blk00z28
Forced to by choice
See is Maxtor will chime in here, he knows (or at least knew) the inner workings of the romulator. Thats what was on my truck when I got it.
TurboJunk
questionable
the truck CANT run without the romulator cause of the injectors, it will start and after about half a minute all you small is gas
ashman
i'm guessing that what you are actually saying is that the truck wont run correctly with the original chip installed.
is the bin your emulating tuned for your combo.? i'm guessing that it is, but you may be fighting multiple issues. i'd try burning a stock bin to the emu and verifing that it reacts the same way as the stock chip. that should, at least, let you know the emu and computer is operating correctly.
TurboJunk
questionable
thats what im trying to do now, Jwaller sent me my first bin file. and im waiting on him to see when he can send me another one
