romulator problems
scotts4
ADDICTED
Ok i hooked it up with the moet addapter loaded the bin eaver thing went ok started the truck and ran really rich with the check engine light was on like it is in limp in mode data master will not work, snap on scanner will not work and jumping a and b will not flash the cel. it just stays on. I have installed the romulator with the red line to the left and right with no diffrence. I have searced and seen pics of the install and i think i have it hooked up right. any help please thanks
lSyclonel
that happend to me 3 weeks ago, the romulator went bad. take off the romulator and put a chip back in. it will run normal
scotts4
ADDICTED
i just did a motor and and did 84 # injectors
so can not put the stock chip back in but if i put the stock chip back in the scan tool works properly but the romulator is ne and this is the first time i used it ? :-?
