Re: Rough idle w/ A/C on?
I'm gonna go with a chip problem as well. When you flip the ac on, the trucks getting more load at idle. And it's probably dropping your idle rpm's as well. Check and see if thats it. Because if it is, thats your problem.
If anything, you should idle higher with the ac on rather then off. Because you'll have less of a chance of the truck stalling while driving around and coming to a stop with the ac on then the idle rpm's set at the same as non ac. If that makes sense..
