Espritmike
Well after replaing the injectors to #60 a 3 bar map, a turbo tweak chip, UR6 plugs and intake gaskets, my Typhoon rund way smoother. Yesterday it did just randomly stall when coming to a stop---no big deal, BUT today after running fine for about 15 min it started runnig very rough after a full boost run (3-5 sec.). It felt like it was pig rich or the vac to the brake booster was disconnected. By the time I got it to my shop (about 3 min away)it was 75% better. The check engine light came on with codes 21,42,and 44. I ran it for about 10 min and it started running normal- all sensors normal. After sitting for an hour it drive fine. I'm thinking a bads ECM but it didnt do this before. Any ideas? Chip, im pretty sure, is seated correctly, and I doubt it has a bad TPS,O2 and Knock sensor (as described byt he three codes). Any help would be appreciated.Thanks Mike
