RPM Downpipe gasket?
Sean Krupa
Moderator
Do you guys weld the Wastegate pipe going inside the Downpipe after you get the correct position for the Wastegate?
Thanks,
bezerk
Re: RPM DP Wastegate pipe?
i wouldn't not clamp it, it doesn't leak
Sean Krupa
Moderator
I made a Gasket out of some gasket material and thought it might be a good idea for the Turbo to Downpipe just for extra insurance for a leak. Do you guys recommend doing this or do you think the gasket will just blow out?
Thanks,
WyoSyclone
Re: RPM Downpipe gasket?
If you use the gasket I would coat all the surfaces with Permatex copper gasket sealant, bolt it together, then let it sit for 3 or 4 days before starting it. I've had great luck with that method on header gaskets on my old Mopars.
jharrison
I asked Mike at RPM if there needed to be a clamp or something on that portion of his downpipe, and he told me that the pipe expands enough with heat that it seals. So no clamps or welding necessary.
Also I did exactly what WyoSyclone did on the flange, except I used a different brand of copper sealant. So far no problems.
