RPM Exhaust Install....HELP!!
hardtailcfl
Ok, so needless to say I'm feelin pretty dumb right now. I just bought a 3" catback stainless exhaust system w/muffler from Mike @ RPM for my Ty and cannot for the life of me figure out the tailpipe! Anyone here installed one and have any tips? Or maybe a link to some instructions? The only instructions I could find on RPM's website were for a Sy. Considering their website says direct bolt on in 30 min or less, I feel pretty much completely embarrassed posting this :(
I have tried everything, including searching the forums and haven't been able to come up with anything. I emailed Mike but he is out of the shop until the 14th. If all else fails I guess I can wait until he gets back, but just hoping someone on here can help me. Thanks!
gib74
Re: RPM Exhaust Install....HELP!!
Whats wrong with the tailpipe??? Is it not fitting on the the exhaust pipe itself???
hardtailcfl
Everything seems to fit fine (and the quality is excellent) except when it's under the truck. It is always rubbing either the gas tank, the shock, or the rear axle. No position I put it in takes pressure off any of these points. I've tried putting the tailpipe in both ways (as one end is slightly longer than the other) but that doesn't work either. I think I'm missing something obvious but my brain is fried right now :(
Norm
I have a full 3" on my ty. It is very tight under there. Mine does rub abit against?? I can't remember what right now,unless I go out to the garage and look. But there's not alot or room ther for 3 inch pipe.It does sound good though.
gib74
I kinda had the same prob. See if this helps ( Or maybe you have already done it ) Loosly snug up all the bolts from the muffler back. You should be able to adjust the pipe with the funky bend away from your rear shock and gas tank. Then adjust your tail pipe. I'll send ya some pics of mine.
hardtailcfl
I think TIGHT is a huge understatement. There is hardly any room back there. Would having the rear end lowered have anything to do with the fitment? I think there's 2" blocks back there.
gib74- I have tried loosely bolting up everything but no go. Pics would be awesome! I'll pm you my email address.
Daron
My Ty is lowered, has the ATR 3in Cat back and fit is good, no rubbing. These trucks are just too funky tho. Put a part on one truck and it fits fine,put that same one on another and it doesnt.
ZavzTy547
Senior Member
hardtailcfl said:
Are you sure? I can even offer up 23" of snow!
Its a very tight fit on lowered trucks but with alot of fine adjustments, it will eventually fit.
Make sure your hangers are adjusted properly and strap your emergency brake cable down, so it doesn't touch the 3" tailpipe, or you will throw sparks at night....
ShuggsRR
Anyone have a picture of the exhaust installed from underneath?
Thanks
wildphil
I Love My Ty's
I had problems with my tailpipe not clearing also. After cutting it and rotating the pipe and having the piece welded back on it cleared. Looks good now. And sounds nice.
hardtailcfl
Well I actually quit fighting it and sold the tailpipe section to warmpancakes. I ended up putting a turndown right off the muffler. Sounds pretty good from the few times I've actually heard it run :tup:
