Re: RPM flutter
Ok now I got some weird things happening with my truck. I have done a lot of reading and searched this site many of times. I have learned a lot. (not enough to fix this myself) . First the symptoms. When the truck is cold it wont usualy start right away. It does the click thing. everything dims in the truck but no starter. Ok sounds like the purple wire, but when its warm the truck will start on the first try. that sounds backwards to be the purple wire. Anyways I bought a conrad remote starter solenoid to get rid of the purple wire. Next symptom, It idles rough. ok but when it gets warm, (over 30 min running) it idles bad. I stopped at the auto parts store and it kept dieing out. WHen I turn on the lights or adjust the heater controls the idle will move up for a few seconds and then drop back down. I got a IAC valve, new battery(cca test was low) and some cone washers to reground the truck. The alternator at idle puts out 13.7volts. I will put everything on this weekend. While I am at it anything else I should try.????? I am looking for the datamaster cables but I have had no response from the guy on this site about them. any tips on the solenoide mod. The search showed some pics but I would like to read more about it. Thanks
