rpm intake?
burmeister
Today forecast High Winds
well after 35 days of waiting for my intake I finally got it. anyone ever put this on? I know it isn't rocket science but any good pics cause it didn't come with instructions? anyone?
0966Sy
Code what?
Re: rpm intake?
You talking about an upper or lower, post a pic of it.
92TyLA
Re: rpm intake?
CAI? Gotta bend the a/c line just a little to slide the pipe in, i remove my battery when I remove or install it back
1slownotch
Re: rpm intake?
There is a few good pics on their forum section, but the install is pretty straight forward. Remove the battery to install the new plate, locate the new overflow can where the factory airbox was located, bend the AC line up ever so slightly, re-install battery before you put your new CAI on the truck, and last but not least install the CAI pipe and air filter. There will be a few other steps in there, but you get the drift. And before you install the CAI pipe, make sure you drill a hole in the pipe and mount a nipple for the PVC breather hose unless you have other plans for it. I'll try to get some of my pics up for you tomorrow. :tup:
burmeister
Re: rpm intake?
Awesome thanks so much for the info and you could post a few pics when you get the time that would be great...:tup:
92TyLA
Re: rpm intake?
Try to bend your A/C line back after you install it or this will happen ......
92TyLA
Re: rpm intake?
air filter cone turned gray after 2 years.......maybe its time for a K&N now:roll::tup:
Flyin Ryan
hated cuz he drives fords
Re: rpm intake?
Should probably make some kind of heat shield to block the the filter from sucking up teh heat from the turbo
burmeister
Re: rpm intake?
Thanks for all the pics and info Im going to tackle it tonight when its nice and cold in the garage. ill take some pics of it done. Thanks:tup:
