RPM turbos
sytyguy
Moderated User
Re: RPM turbos
IIRC, the 60-1 is a 61 lb/min compressor wheel and the 61 (GT35R wheel) is a 65 lb/min wheel.
BoostedSUV
Re: RPM turbos
I bought a 60-1 setup a few years back it was a precision turbo. That ma have changed though.
DanenGraham
Big in the rear
I have the 60-1 it's just like the picture (6-7yrs ago) The picture still shows the ITS minigate 35mm, it looks like. Not the 38mm rpm unit you should get with a new purchase.
ITS is no longer around from what I understand, changed name to something else. I'm sure Mike knows.
Treymen
Re: RPM turbos
I really wish they would update their site. I've heard that they have several other turbo options available now, but with it not being on their site, how would anyone know????
ghettosled
SYTY SUPERSTORE
Re: RPM turbos
Fwiw, Precision turbo is the only company that makes a comparable turbo (and in order to work you need to run our downpipe)
As far as turbo specs, if you don't know what you need just call or email us. We provide the latest cutting edge in technology but can't justify the time necessary to constantly update the site. Most of the turbo kit turbos are shipping standard with CEA billet wheels when sizes are available. The waste gates are usually ours or the PTE 39mm.
Treymen
Re: RPM turbos
Heres my plan:
Typical spec built shortblock,4-bolt, eagles, pistons, crank blah blah blah
P&P'd L-35's with 2.00 intake 1.6 exhaust
Alky
60# inj
Electric fan
A2A
A/C delete
3" exhaust all the way out
With all that, looking for a kit to push it into mid 11's 11.7 at the VERY least
I'll give u a call sometime this week
Icarus-54
Donating Old Member
Re: RPM turbos
Go with the PTE 62/65 dbb w/billit wheel,quick spool and pulls like a bitch,besides that's as big as you can go safetly w/60's
ghettosled
SYTY SUPERSTORE
Re: RPM turbos
my recommendation also (actually the new turbine wheel is a 66 not 65), but std bearing if you dont want to spring for the dual ball bearing which is almost $600 more.
Treymen
Re: RPM turbos
Do you offer this in a kit like the above mentioned link?
wildphil
I Love My Ty's
Re: RPM turbos
The 6766 would work great with for planned build. My build is very close to what yours will be. I have a 6765 turbo(the 66 wheel is now being used instead of the 65) and I am very happy.
Treymen
Re: RPM turbos
If PTE has replaced ITS, and I wanted the 61 not the 60-1, what is the turbo from PTE that is comparable, maybe even a tiny bit better, but not smaller than the 61 that is a 65lb/hr?
I'm shooting for around 620-640 hp at the motor, but I want very very fast spool time. And yes I will be running a 2800 stall
Icarus-54
Donating Old Member
Re: RPM turbos
Once again--pte 6266,I run a 6265 and so does Areoking(Brandon).See his post at homecomming with his truck on the dyno.That's about as big a turbo that you would want with 60# inj.
SYCLONE#1531
'MOFOFAST
Re: RPM turbos
I would go with the new 6766 CEA Turbo like im running on my truck.. This run was with a stock cammed LB.60lb inj, Fueled by meth and 93 torco mixture. Truck was running very rich on this run...
http://www.youtube.com/watch?v=agrCa9EAzD8
Aeroking
e.i.
Re: RPM turbos
I have basically the same engine, running a 2800 9/11. Mine spools boost right around 2600 (CEA wheel, non-BB). Very streetable compared to a 70 series turbo with the same motor. I think precision rates the 6266 at 720hp. Your goal of 620hp @ the motor, 20% driveline lose is right at 500 to the wheels. Good suspension & DRs should put it low 11s.
The 70s series should have a big cam, ported vortecs or better heads.
ZavzTy547
Senior Member
Re: RPM turbos
With your build, I'd go with atleast a 60 series and while your at it, may as well go with a BB turbo
