RPM Valve Cover install
Ian Turgeon
Cascading Inspiration
I'm working on installing these now, first time I've removed a valve cover so give me a little room to make myself into an idiot....
(stock heads)
These things are monsters: I started on the passanger side and theres been a little more work involved than I was expecting. Had to remove the IC brackets, the bolt that holds the oil dipstick, and even had to loosen the bracket that bolts the AC pully bracket to the lower intake manifold to make room to slip the beast in place.
Right about now is when I realized the bolts I used out of the stock valve covers wont work here at all, so I guess Im off to Lowes to pick some up. Looks like these will require a bolt thats ~ 5 1/4 " long, so hopefully I can find some good hardware there...
I havnt gotten to the driver's side yet but that looks like it will be just about as much fun with the brake booster and map/coil bracket there.
I'm just mocking em up for now to make sure the fit before I attempt to paint/install them. It looks like the IC brackets may be a very close fit if I can install them at all..
Along with this Im trying to figure out exactly what I want to to with the PCV/breather options, I've nearly descided on simply running a breather on both, or maybe a line running to the intake on the passanger side so that its able to pull a little more vacuum at high rpm where it could help performance a bit.
Any advice from others using the stock head valve covers? Also anything I can do quickly while I have access to the top of the heads? Check valve clearances? lifters? so on... How about valve seals? are those do-able from here?
I'll have some pics later as this goes along..
93ty475
Re: RPM Valve Cover install
The stock I/C brackets didn't work for me....I fabbed a quick/custom I/C bracket to clear the aluminum covers before I went A2A....if you need a pic of it, let me know....As far as the bolts go, get them with longer threads and cut them down....also you might need copper washers as mine leaked before I installed some....I don't know if you have the old or new style covers, but mine were the old and the rear corner of the passenger side rubbed a small hole in the a/c box....you might need to tie the motor down if you don't have solid mounts in yet....also the driver's side one is a tight fit between the alternator and brake booster....if you wrap them with an adhesive cellophane for install purposes, you might avoid scratching them up....
Ian Turgeon
Couple of good tips there. I'm using the newer style, they may give me a little more room, so we'll see with the ic brackets and ac box, I'll have to try the cellophane trick.
I got some 5 1/2" bolts fom Lowes and they look like they'll be perfect. The passanger side fits, so I started removing the drivers side.
I think I may have to remove the alternator bracket that bolts to the manifolds, except I never realized how that thing was bolted on, I pulled out the alt bolt, the two manifold bolts expecting it to come off... Looks like theres more to it, I think theres another nut behind the power steering resivoir that Im having a hell of a time getting at... I may try and get around this damn thing as its getting a little more involved then I thought it was.
Back to the garage...
Ian Turgeon
squeezed the drivers side in.. a couple of things there. I had to remove the coil/map bracket, engine hoist bracket, alternator, brake booster line, throttle linkage and the basically everything the wiring harness hooked up to. Only thing left was that alt bracket that connects to the manifolds, I basically wrapped a hose clamp around it and the alt pully bracket to sinch them together a bit, I could see the valve cover inching its way down into place as I tightend the clamps, so it helped give me just enough clearance to get this cover in.
I'm going to use two breathers right now, I drilled the holes w/ a uni-bit (first time I used one.. pretty cool) and now getting ready to paint...
Its actually easier to sit this side in then the passanger side is.
bezerk
i had to grind down some of the alternator to make it work on the drivers side, further than that, it was an easy install.
A2A here also
Ian Turgeon
Got to installing last night. I picked up a set of felpro gaskets from autozone, They are short so you have to use glue and stretch em... a stupid design. So I got out and buy some 3m spray designed to stick metal to rubber and put all that on. As soon as I take off the clips to install them, the gaskets pop off.
The stock ones fit fine w/o stretching, so can I re-use these things or what? I have no Idea how Im supposed to get those felpros to stay in place.
