Running a little rough
Re: Running a little rough
FOUND THE PROBLEM. Bad spark plug wires. I noticed smoke coming from two of the drivers side plug wires. I removed the fiberglass heat sleeve, and what do you know. A bright blue spark is arcing off the exhaust manifold in tune with the missfire. It's also my birthday and I'm 22 now, so today is a good day. I can't believe I replaced everything but the plug wires during the tune up, and that was the problem.
Curious to see if you have the little hiccup at idle in park still.
It's got a little bit of a Hiccup at idle still, but it is definitely running 100x better and no longer missfiring with the new plug wires. I can feel comfortable driving it now. As long as the little hiccup is normal, then I'm ok with it. The only problem I have now is that there is still a little Smoke coming out of the fiberglass spark plug sleeve on the drivers side, middle plug, when it gets warmed up. The sleeve is touching the manifold, do these sleeves normally smoke when they get hot?
JoeSupra
I was told the hiccup is normal and my truck drives really good now. Idk much about the sleeves. I don't have them on mine.
