Running good then bad then good, code 43
bender
I took my truck to work on christmas eve. It ran perfect all the way there. When I left that evening, as I pulled out of the lot it stumbled a bit then went fine. I had been running the gas really low to get rid of crappy gas so I could fill up with shell. I thought maybe it was getting pretty low so I went and put about 10 gallons in.
Then I drove about 15 miles down the freeway, ran perfect. Parked it at my parents house for about an hour while we ate. Then I was going to take my brother for a ride. I went and warmed the truck up. As we pulled out of the driveway, it was sputtering and falling on its face. If I gave it more than half throttle, it went fine, but to try and cruise along at 30 mph it was bucking and rpm's were going from 700-1800ish, up and down up and down. If I got on it it would take off like nothing was wrong.
I didnt want to mess anything up, so we grabbed the car trailer and took it home. It took us about 3 hours before we got it to my house. I backed it off the trailer, and it was running fine. I drove around the church parking lot, no issues at all.
I had to leave for a trip the next day so I didnt get to put it on datamaster until today. I drove up to the parts store, then took a little run down the freeway, no issues other than the dtc code 43. It is not giving me a CEL, just on datamaster. It seems to run ok, but I am still getting a little stumble as soon as I accelerate from a stop, just for a half second then its ok. It ran good for the whole trip, no problems.
I looked on here for what was code 43 and the general consensus was a knock sensor. When I installed the knock sensor after the rebuild, I didnt know about its torque spec so it is entirely possible that it is too tight.
I get an instant 3.0 degrees knock retard every time I hit the accelerator. I dont know if this is because of faulty sensor, or maybe the engine tie down is too loose and its banging every time the engine torques. Or maybe its normal???
I also am still getting 6-9 degrees of KR on wide open throttle runs, but not until boost hits the upper region. I put shell 92 in because that is the best I have here in Yakima, there are no stations that have 93 for 100 miles.
Is my knock sensor causing this, not enough octane maybe, bad gas caused the stumbling??? Any help or guidance would be appreciated.
here is the datamaster I took today just to see if it would do it again
http://www.mediafire.com/file/ndatacnd3yb/studderrun1.uni
Re: Running good then bad then good, code 43
Did you replace the knock sensor after the rebuild or reuse the one that was in there? I seem to remember someone having a problem with code 43 b/c they got the wrong sensor, but search isn't cooperating at the moment.
bezerk
if you got a code 43 it will cut back timing everytime you are on the throttle with an steady amount of KR. it's a safety thing, you could try to reset the ecm by taking the fuses ECM A and B out.
maybe a bad knocsensor?
bender
I reused the original. I went to the parts store today too see what they had. They had two, so I need to figure out which one is right,
bender
I disconnected battery and pulled the ecm fuse. It was still there. The weird thing about the KR is it only pulls it right when I step on it, then it goes away.
bezerk
goes away if you get off the throtle, right? that's normal for 43
BoostedSUV
Parts store gave me the wrong knock sensor a few weeks ago and it kicked a Code 43
BoostedSUV
The correct knock sensor is part #KS6 I believe and that's for the brand Standard. The parts store had KS7 listed for Typhoon and it wasn't correct, I later looked it up and KS6 is correct.
bender
depends on how I get on the throttle. If I ease on like from a stop light, and normally accelerate, it does not pull the KR. If I am just rolling down the road and tap the throttle real quick, thats when it pulls it, is that was is normal?
here is a screen shot of what I mean, the first is getting on throttle for normal acceleration, the second is tapping the throttle.
BoostedSUV
My truck will do the same thing if I ease into throttle... Won't show any knock. If I just smash it to the floor it will get a few degrees of kr then it will level off and timing returns to normal. I'm pretty sure that's normal due to the fact that these trucks cruise around with higher levels of timing than they do at WOT. I assume that the sudden WOT and the addition of boost the ECM won't react fast enough to pull timing so you will get a small degree of KR initially. If you continue to have KR and it doesn't return to normal at steady WOT that is not normal and dangerous.
This will also depend on how much boost you're running, how quickly the turbo spools and if you get any boost spking. Could also be false knock from the motor torquing, fuel lines hitting the tunnel etc
bender
OK seems alright then., does it seem I should replace the knock sensor then, is that the general cause of the code 43, or maybe should I just try loosening and torquing to proper specs.
BoostedSUV
Your graphs show a bit more spark retard for a longer duration than I see with my truck... Don't really like the look of that. My truck gets a quick KR spike on the graph then returns to normal while still maintaining full throttle
bezerk
Code 43 can point to the Knock Sensor but it appears it is working since your truck detects knock. Code 43 also points to EST bypass wire and Ign module as well.
code 43 shows knock, it will pull timing, replace the knock sensor!
BoostedSUV
43 is knock sensor, and associated memcal for KS. 43 is not related to EST or distributor issues.
Code 42 is Bypass wire, EST, and module. 42 is not related to knock (43).
EDIT: Dave you are correct (not that I doubted that) I went back and checked and I did have the 2 codes reversed in my head. I got a code 43 with the wrong KS installed NOT a 42. Sorry for the wrong info... I went back and edited my posts to save some confusion.
BoostedSUV
After getting my info straight I definitely suggest changing the knock sensor as well. What could it hurt? I think I paid $40 for a new one. Just make sure you torque it to 14lbs because too tight will make it extra sensitive and too loose it wont be sensitive enough.
