Running IC hoses through Heater Core?
Syclone#2960
What ever it takes!!
A good friend purchased a clone w/ this mod.Has anyone else had good or bad feed back on this?
I am thinking about removing the stock metal lines and replacing them with heater hose but bypassing the heater core as well.Maybe when I turn on the AC it willl help chill the coolant faster. ::eek:ndrugs::
________
Fuc Tube
tbauer03
TRBOBOX
Yeah Don (sy112) Took his ic lines through the heater core and his iat temps dropped dramatically. He got a premolded hose from a local parts store that was designed for a honda or something and it was pretty clean.
InvisiBill
I think Daron did that also. It's essentially the same setup as stock, except that you can use cold air instead of ambient on the heat exchanger part. I do believe the AC clutch turns off at WOT though. so make sure you take that into consideration.
If you're trying out weird IC stuff, you could also try plumbing it into the "warm up" passages in the throttle body. It's made for passing warm coolant through to keep the blades from icing on NA vehicles, but you could use it for cooling. Someone else here mentioned that once...
ZMann
vertically challenged
Im thinking i need to try this. Not sure if my atr aux ic is even worth it. Effects my a/c and other cooling issues. Or in that case, my 500 dollar atr upper.
Somtimes too much is not enough.
Might try something else.
Typhoon #1133
i have had my truck like this for about 2 years now. water temp will drop about 15 deg max and Ic temps will only drop about 5 max. But engine temp will go up also. i have not tried it at the track yet. i have tried it with the stock and the ATR upper intercooler. it works better with the stock since there is less water to cool. It takes about 10-15 min. at idle to cool all the way. I have the lines running from the upper intercooler to the lower intercooler to the heatercore and then back to the upper intercooler.
Joey Allen
MUNCHKIN
I did mine like that but used pieces of the existing metal lines to make the connections behind the I/C look clean. I will have pictures to see on GAST website soon, Michael's working on my link now. Hopefully within the next week, just look at Joey Allen '92 Typhoon.
sy2206
Dig and I had talked some time ago about taking some old A/C lines and cutting the fittings off of them. Weld them onto the intercooler where the coolant hoses are, and get some new A/C lines made. Now you're running the freon through the intercooler. That would be super cold, I guess somone did this several years ago and it worked sweet! Would make the A/C in the truck warmer though.
You could also get rid of some weight because you could remove the CCHE and intercooler lines.
ZMann
Sweet... that would be cool! I never use my ac... and deleting ic lines/parts would be a plus. Mark, go ahead and do this mod and let us know how it works :)
SY756
Yeah that was several years ago. It was called the "intracooler" and if I remember right, it was quite a bit larger than stock but it had basically 2 compartments or "cooling chambers". One for the freon and the other one had water for cooling still. So it really didn't save any weight since it retained the water cooling. Too bad it never really took off.
bigtime
Sy-Ty Builder
I think it would be really hard on the compressor. Would you
really pick up that much turning the compressor? quick reving
engines destroy clutches.
just my .02
SY756
I think the idea behind the intra-cooler was that you would have the cooler already saturated with extremely cold air, then if you did go WOT the compressor would kick off and you would have enough cold saturation to last for about 10-15 sec before it got heat soaked. And IMO I wouldn't want the compressor on at WOT since it draws a fair amount of HP, and we all know that we always want MORE POWER
Will_in_China
Truckless Wonder
I kinda like the "Always on" power items (air/air or upgraded upper IC) or ones with a Dramatic effect otherwise (ie. alchy). I don't see any real big numbers coming out of the cost benefit analysis of rerouting.
Maybe someone needs to "officially" do a pre and post, double blind, datamastered analysis, etc...
I think keith has had it and has measured it, which shows the most results which are that it doesn't do much, correct?
And if you are going to plumb it through the intake, I would gather it would need to be on a perfectly working air/h20 system (i.e. full of fluid!, pump working!, no air bubbles!, and maybe even some soft lines?) for it to NOT be a deficit in peformance.
I can just picture somebody making all these changes going through all this effort and then their original IC system was not "perfect" in the first place and it getting worse by pumping hot water into MORE places...
Just my 2.1c....
-W
sy112
just to clarify, in my situation, when i routed them through the heater core I saw around a 15 degree IAT drop cruising around town in the hot KC afternoons. This is with basically everything stock on the intercooler. Tis true my engine temp would go to about 185 or so instead of the usual 165. Now as I understand it there is a table in the Ultimate that pulls timing out when the engine temp goes up cause our stock heads are detonation prone. Would like to figure out a way to eliminate that being as I am spraying and my IAT are pretty damn low with routing through heater core.
In 95 degree KC weather I would be cruising at around 105-110 IAT's and after a 0-100 mile blast I would see around 125 or so, thanks to spraying water at the time. Have noticed alky cools a little better and am planning or spraying that and adjusting fuel tables.
I understand the theory of compressor turning off under WOT but spraying helps eliminate that problem.
In short I think this is the best "free" mod you can do in the summer. MHO
ZMann
I've been thinking about doing this mod. Not sure if i'll get to it or not.
Don, did u get moved to Dallas ok?
laters
Typhoon #1133
on the street there is no way to keep the engine cool doing this. at the drap strip all you need to do is take one of those round up weed sprayers you can pump up and pray the radiator down. it will cool the engine down to 160 deg from 185 in about 2 min. after i get my alky set up i dont think i will mess with this anymore.
ZMann
Well Hell, i better not touch this mod... my engine temps already run at around 185 while cruising around 70 degree weather. Im eventually gonna get a aftermarket water pump, and move my tranny cooler below. I have the 160 degree therm. Atr aux. ic. Not a whole lot of airflow to the radiator with that.
sy112
yeah Zach, I'm finally getting settled in. Just got my internet today. I am thinking about routing it back to normal, it takes some of the cool off the AC, and man do I need all the cool I can get down here in Texass. :-?
Like 1133 said, it seems to be pretty hard at getting the engine temps down doing this. But man I love seeing those sub-100 IAT on nice mornings :lol:
