Running rich at start up
sharky207
When i start my ty it runs really rich. The motor is spitting and sputtering and i have to keep my foot on the gas to keep it from stalling. When holding my foot on the gas the motor acts like its almost missing. It blows a lot of smoke out the exhaust that stinks like gas. If i let the car idle for a few minutes i will get a code. I dont remember the # off the top of my head but its the rich idle code.
What could make my truck run extremely rich at start up? Do you guys think that my injectors are leaking???
sharky207
if i can't see or hear the leak how do i check for one?
Is there any type of diagram that we have to see what it looks like besides what they give you under the hood or in the manual. Is there a diagram on one of the syty links?
sytyguy
Moderated User
Spray starting fluid around all the vac lines and listen for the engine to rev up. A leak can develop in a line as well as some gaskets (TB gasket, plenum gasket, intake gaskets, etc...). Keep in mind that the bushings in the TB shaft can be a source as well. Other than that, spray the lines & the items below. Won't take soaking it with fluid as it will be sucking it in.
Items sourced to vacuum:
- MAP
- FPR
- EGR
- Vac Ball
- Cruise Control
- Charcoal Canister
- A/C
- Brake Booster
* If truck has been modified, then a boost gauge line will be attached and some aftermarket turbos require a boost/vac signal for the WG to be drawn from other sources than housing nipple. Keep this in mind.
Do a search for a detailed schematic of a vac diagram - someone had posted one here before (not too long ago IIRC).
HTHs
Michael
skata
it dont sound like a vac leak.
more like a stuck or leaky injector(s) or the idle/speed solenoid not working.
check your fuel pressure and see if its within specs and check to see if the pressure doesnt bleed off fast when you shut off the engine.
also you can check your spark plugs to see if any of em are wet. possibly only in certain cylinders?
sytyguy
Moderated User
Agreed - it doesn't sound exactly like a vac leak (although I wouldn't rule it out). I just wanted to give some tips on how & what to to check in the event of a vac leak.
Skata sounds correct.....stuck injector, base FP way too high, etc....Check those first. Don't rule out the possibility of a dropped cylinder (anything from a bad plug wire to an intake valve not opening). If fuel testing turns up nothing, might check and see if plugs are getting fire (visibly). If one cylinder is particularly wet, pull valve cover and check for a broken pushrod, boken spring, collapsed lifter, etc....just verify that all valves are opening properly.
Just throwing stuff out there. Do the easy stuff first and keep the rest in mind if nothing turns up.
HTHs
Michael
SY756
If you havent found the problem yet, you might want to check the FPR. The diaphram in mine got a hole in it and it was sending fuel strait into the vacuum line then right into the plentum. That could cause your trouble. You didn't say if it does it all the time or just sometimes. If its just sometimes then I would say it's not the FPR
sharky207
The longer the truck sits the worse it runs when started. I think this also has something to do with the truck revving from idle to 1500 rpm while in drive with my foot off brake and gas.
skata
are you saying that the truck revs up by itself to 1500 rpm? i thought you said you have to keep your foot on the gas to keep it from stalling?
sharky207
The truck revs up to 1500 rpms when im cruising with my foot off the gas and brake. This happens sparatically while im driving and not at idle or start up.
sharky207
well i checked the plugs and found nothing. Im leaning towards a fuel problem because the longer the truck sits the harder it starts and dumps more and more fuel out the exhaust.
I would try cleaning up the IAC on the iunder side of the Throttle Body. I have had leaky injectors before but they never caused intermitant 1500 rpm idle. I would also replace all the vacuum lines if they are original, youi may have multiple problems going on if your truck is mostly original.
SY756
sharky207 said:
how involved is changing the injectors?
Not bad at all really. When I went to 50's I didn't even take the throttle body off, you will of course have to take the IC off. There are just 2 bolts on each side holding the fuel rail on.
BTW did you happen to check the FPR?
SY756
sharky207 said:
i havent checked the fpr yet. Is all i have to do is take the vac line off and see if there is fuel in it?
Yep, pretty much. If you want to make 100% sure you could take off the vac line, plug it and start the truck. Actually you could probably just turn the key on.If the diaphram in the FPR is blown, gas will start shooting out of the vac fitting on the FPR. Probably not the safest thing to do but that's how I found out. Gas shot out of mine like a gyser.
turbodog
There are some simple FPR tests you should run. 1st, a fuel pressure check. FP is so critical on these trucks, a $30 shop FP guage is a must-have item. I've had a FPR fail so as to allow full pump pressure to the injectors. I got a rich conditions like you describe.
Second, if you have the guage, you can diagnose a leaky injector without pulling any. run pump to pressurize system. Clamp fuel supply and return hoses where flexible hose is (at bottom of firewall). I used vise-grips for this. If fuel pressure goes down, you have a leaky injector (or pinhole in diaphragm). If FP remains constant, no leak.
I agree it could be the temp sensor (or wiring). If it has intermittent OPEN, ECU will think engine is COLD (like 40 below zero cold) and go super-rich. I had an Astro van with this exact problem. However, this will store a code 15, so you can check this easily.
sharky207
Well im in a pretty tight spot. Im low on $$$ and short on time. My truck is getting extremely poor gas milage. I've used to get around 13mpg around town with getting on it here and there. The other day i checked and it was almost ten miles to the gallon. The trucks bogging out pretty bad and if im flooring it the truck wont run right, its spitting and sputtering at high rpm's and it never did that. The truck is still running horrible at start up after sitting over night. and when im revving it to keep the truck from stalling im pooring out black gas smoke from my exhaust filling the driveway.
I think whatever problem i have is getting worse. When i hooked the the fuel pressure guage i had about 44lbs of pressure. I let the guage sit after turning the ignition off for about 5 minutes and didn's see it drop.
If i have leaky injectors would this make my truck run rich??? Is it possible that my computer is bad?
IM in Middletown, N.J. and if i have to bring it to a performance shop does anyone recommend a place that has worked on syclones and typhoons
SY756
Well, it sounds like you've ruled out the fuel inj'rs and FPR by checking the pressure and if it's not dropping after you shut it off, those should be ok.
? Have you ran any type of scan tool on it? One thing that comes to mind is possibly a bad TPS sensor sending the wrong voltage to the computer, that could screw it up. Im just thinking off the top of my head.
I'm not that familiar with Jersey, well not at all, but I do know there are a few guys up there, maybe not close but, they might be able to help you out. Morgan, Nick, 92 Typhoon. It may be a different story there but I don't trust any shop around here to work on my truck.
