Bill Z
On the infrequent times it gets cold down here; my Typhoon stumbles or hesitates at around 1800 to 2000 RPMs under normal driving acceleration. The problem isn’t noticeable when the outside temperature is above 70 degrees or the engine is warm. Just when it is cold outside and the engine is cold. For those that may remember the old carburetors, it is like not having your choke hooked up on a cold morning.
Is there a sensor in the Typhoon that tells the computer to squirt more gas because it is cold? If there is, what is it called and where is it located? Better yet, how do I diagnose this problem to make sure what the real problem is?
Here is what I got. 92 Typhoon with 65,000 miles. I just put new bug, cap and checked the gap on my NKG UR5IX plugs. I am running the factory ignition coil (Borg Warner coil about 9 months old) with AC Delco wires (also 9 months old). All of this is controlled with an Ultimate chip.
Under boost, the little truck runs great.
Please help.
Please help.
