SB Dipstick and waterpump
Norm
Re: SB Dipstick and waterpump
I would like to upgrade engine dipstick since it is not sliding smothly anymore, anybody who know if a lokar for 80 up SB will fit? like this one. http://www.jegs.com/i/Lokar/625/ED-5001/10002/-1
When ordering a waterpump, I assume SB 80 up will fit? short or long? Thanks.
I have a lokar oil dipstick on one of my engine. Thre is some play there as they are cut to length for the correct oil level. Before you swap the new one out,make sure the oil level is correct on the original one, and then match up the lokar to the right level. As for the water pump, make sure you know if it is reverse rotation or standard rotation.
cat-vi
Ty Wannabe
Hmmm, one step forward and one step back there, when I look at pictures of the lokar dipstick (or other brand) they seems to be quite short measured from where it enters the block and up to the handle, is this the issue? or is it the size of the hole in the block where it should seal? I meen, if any issue, when it comes to the water pump, I need the reverse rotation, long pump?
Quickstop [UK]
Combating adversyty.
The size of the bore in the block is smaller than the diameter of the dipstick rod. We tried milling it but ruined it.
nallj92
ive used a SBC lokar but did have to have it milled. it works fine but is short and hard to get to in the engine bay once the downpipe and turbo are installed. I wish i would have used a stocker instead or just bent up my own.
Quickstop [UK]
Yeah, I tried putting the stocker in AFTER I put the manifolds on and the engine was in. Total cluster.
You need to take the manifolds off to do this properly.
cat-vi
Ty Wannabe
Ok, thanks for the warning, I'll get a stocker. The manifild is out, looks like a great deal of fun to put back:) I guess it would be easier to rip out the engine and put it back with exh.manifold allready bolted on, what about retightening of cylinder head bolts after assembled engine with new cylinder head gasket, do you guys remove the exh.manifold to retighten, seems to be a loooong day when I finaly get my cylinder heads. Or do you use cometic and save your self from some xtra fun?
Quickstop [UK]
I used Cometics. Is the block surface prepped for them though? Needs to be 50 RA I think.
I didn't tighten mine after you do the sequence. 45, 55 and 65 lbs.
Both heads are off? If you had the space, it's going to save you a lot of hassle to pull it. I wouldn't try fitting the head with the manifold attached. It will be hard to handle, clearance might be an issue and you'll prob mess up the deck/gasket/ head in doing so.
Quickstop [UK]
Also, I used ARP studs and replaced the stock bolts. If you do that, make sure you have the right moly lube for the heads to get the correct torque spec.
You should start a project thread so we can follow :)
cat-vi
Ty Wannabe
Both heads are off, the deck is not surfaced so I won't think about cometic then. A thread? hehe, don't hold your breath, it will take a month just the shippment of the cylinder heads and intake from Canada, and then it is time for me to go back to work for a couple of month, we'll see.
