Re: SBC Rods in a 4.3?
i see what you're saying. What i was reading on the topic was talking about EFFECTIVE stroke. My bad.
Because of the mechanical advantage provide by the toggling effect of the rod the shorter rods act as if they were in a longer stroke engine at the top of the stroke. This effect would make the short rod engine rev faster from 2000 to 4000 rpm and the circle track people claim that acceleration out of the turns is significantly improved with the shorter rod. In all other factors the longer rod comes out superior...
Here is some more data on the 2 rod lengths if you never saw it:
Dwell time at TDC for 3.48" stroke:
6.0" rod: 54.929 degrees
5.7" rod: 54.605 degrees
Percentage difference in dwell time between the 6.0" rod and the 5.7" rod is 0.593% at the 3.48" stroke.
Rod Ratios (3.48" stroke)
6.0" rod: 1.64
5.7" rod: 1.72
Longer rods, which result in a higher ratio, favor the mid and upper RPM area. Shorter rods, or a lower ratio, improve low-end torque. The ratio should fall in the range of 1.65 to 2.00
I wonder what kind of torque numbers you'd see w/ a 6" rod. Also, given our typically low rpm spinning motors, seems like you'd benefit w/ the 5.7"
