scan tool ?
warsaw
Sy#1012
what kind of scan tool do i need to run a check like this. i had a scan tool but did not give me this kind of info are let test like this is asking.
[/IMG]
berzerker
wookie
Re: scan tool ?
is this the same code that was coming up when you purchased the truck and danny could'nt figure out why the code was popping up when driving ?? datamaster will tell you everything that is going on ... almost
spooldup
Super Member
Re: scan tool ?
A gm tech one is the factory scan tool at the time this truck was built. A tech 2 is the newer version and i believe there is now a laptop based system as well. The wording in the manual might be referring to that tool although as suggested a volt meter will do the trick.
warsaw
Sy#1012
Re: scan tool ?
I ain't for sure still got the idle surge. And code 34/35 come up about two days ago gonna fix them and go from there
Syclone22
Re: scan tool ?
Best way i did this check is with a vacuum pump from Snap on
and vaccum gauge just pull vacuum to see if the map sensor is faulty
on the scanmaster and push air with pump to see the boost voltage
are you using a wideband A/F gauge if idle is lean it will surge or
hesitate :roll:
The Bronze
Re: scan tool ?
Just playing around a bit, please ignore the attitude that lies within these sentences and remember that the poster may be sitting here with a couple of cold ones. I also just used the 2Bar specs, since I don't have 3Bar specs coming to mind right about now. Anyways I digress...
Following the trouble tree exactly isn't always going to identify your fault, especially an intermittent. Bear in mind that you want to be testing this when the condition occurs. Code only sets cold/warm? After a hot-soak while getting a six pack at the 7-11? Duplicate the code setting conditions.
My improved flowchart:
Grab a vacuum gauge, cheesey meter and a couple of sewing "T" pins and hopefully a scan tool such as datamaster or whatever. Don't have a scantool? Neither does the ECM. Continue.
Step 1: Visual Inspection. Anything that is going to lower the actual engine vacuum or prevents the actual vacuum signal from reaching the MAP needs to be dealt with. Any vacuum leaks, cracked hoses, brake booster leaking, plugged cat (at idle it would have to be really bad), timing way off). Take the time to check all the nipples and fittings. You can waste time checking electricity or you can fix the most likely problem. Make sure the MAP sensor has MANIFOLD vacuum available to it. If it is plugged into the Boost Solenoid vent, it just isn't going to work all that well. ;) Install your vacuum gauge. Make sure it is connected inline with the MAP sensor ("T"d).
Step 2: (Scan tool users) Key-On, Engine-Off (KOEF). Record your BARO pid, compare it to your local current BARO. It should be very close. (Everybody) If not, record MAP signal voltage (Lt Green Wire). Share your results. You can jump to Step 4, check the 5V ref, ground and signal wire. If they look good, check the signal wire at PCM. It takes a little extra time, but the ECM isn't looking at the voltage at the MAP sensor, is it?
Step 3 (is identified as Step 1 on the chart): The chart wants to know if you see under .25V on the MAP sensor circuit when the vehicle is idling. The computer knows that it cannot produce that kind of vacuum at idle. What you really want to see is if your MAP voltage equals your engine vacuum. Do this step. Put a vacuum gauge on your engine, Connect your whatever brand of scan tool and look at the MAP PID. If they don't match, then connect a meter to the MAP sensor and record that value. Don't have a scan-tool?J just connect to the MAP signal circuit (at the ECM is the best, but more effort. It does eliminate any wiring issues between the MAP and ECM though). Record your results. If this voltage is normal (~.7V at idle/20" vacuum to 1.15V with 16" of vacuum in the event you are rolling with a non-stock cam or random vacuum leaks). Problem not acting up? This is where you lightly tap the MAP sensor and wiggle the wires. Watch the scantool/meter for changes.
Step 4 (Flowchart step 2): The Flowchart assumes that the voltage is low and would like to see if the ECM has good voltage to the MAP sensor and that the signal circuit to the ECM is good as well. That is why you are jumpering the two wires. I wouldn't handle it this way. The voltage is low, and you don't know what the voltages are. You should expect 4V to the ECM, but this is where you just answer the questions. 1) Is there a good 5V reference and ground at the sensor. These are the two wires that are not green. stick your meter in there and record the result, better be 5V or you are fixing that circuit. 2) Now put your meter on the MAP ground (black wire) and to the signal (green wire). Record your results, compared to engine vacuum. If the ECM doesn't read what the signal voltage says, now you can chase the signal wire to the ECM and check it there.
Step 5 (Flowchart step 3): At this point, we have already figured out the problem is at the sensor or it isn't occuring, but on the slim chance that the voltage wasn't reading the same, you can waste your time and apply the 12V to the circuit to see how the scan tool responds. Step 4 already did this without applying 12V to a 5V circuit. I would record the results of Step 4 and not do this test. Doodle on your scatchpaper, scratch your butt or drink a beer.
Step 6 (Flowchart step 4): I have an idea, let's check the vacuum line. I don't think so flowchart, we already did this at Step 1. :tup: MAP sensor must be bad? Maybe. We figured that out at Step 2-4. Open circuit? Nope, checked that at Step 4.
Problem didn't occur/Code didn't set? Yep, thems the breaks. Repeat when problem arises.
In reality, The code setting criteria is very loose, so it should be easy to duplicate this problem.
Here is my test: Without a scantool. Hook my (Scope)meter to MAP sensor Signal circuit and a ground. Turn the key-on, but don't start it. Compare the voltage (BARO at this point) and compare it to local baro. Mine is nearly always around 29.0. Voltage is going to be somewhere around 2.5V. You can google a Volt/pressure conversion table. All good? Start up the engine and let it idle. Vacuum gauge is connected ("T"'d into the MAP sensor vacuum line-compare apples to apples) and I will compare the voltage signal with the MAP sensor signal. I suppose around 1.5-1.6V if you have a BARO of 29, engine vacuum of 19".That would be a guess. My rig is covered in primer and spare parts. :roll: The vacuum gauge better be moving quickly as I snap the throttle. If not, I am looking for a plugged/collapsed vacuum line. If the voltage doesn't match, I will check the 5V ref and ground and then replace the sensor/wiring as needed. If it all looks good, I am going to tap on the sensor, wiggle the harnesses down the length as much as possible and mimic the conditions that seem to set the CEL. Code always sets on the way home from the store after a hot-soak? Guess when I am testing the circuit?
If I have a scantool: Look at the scan tool first at each step, then continue.
Advanced users: Scope for intermittent drop-outs that the meter isn't catching, especially on the tap-test. Record the various readings at different vacuum and pressure levels. Do a linear regression and look at the slope. It should be steady (but probably sloping one way or the other a tad). If the slope isn't straight, a portion of the internal bridge is likely failing and should be replaced. Keep in mind that your $20 vacuum gauge may not be as accurate as the MAP sensor itself.
